is this my speedo cable?
can someone tell me which one of these is my speedo cable?
or am i totally off?
the cable in the yellow circle or the cable in the orange circle?
im asking this because at the end of the yellow circle cable this thing that looks like the cv boot
but a very thin small minature one of those is torn.
could this be the reason why my speedo dont work anymore?
this could really help?
and does anyone know the name of the minature thin looking cv boot thingy?
Re: is this my speedo cable?
The yellow cable is you clutch cable line, the orange one is the your accelerator pedal. The speedometer cable is located under your intake arm held on by a 10mm bolt connected to the transmission.
ohhh.i see but at the end of my clutch cable a tiny cv boot looking thing is torn what is that called so i may replace it.thanks.
and if my speedo cable was to be worn out or has a hole will it affect my speedometer from working?
sounds like a dumb question but hey,???
If it is torn then it will not work but on the hole it depends since it is mechanical. Did your speedometer always work or did it recently start to malfunction?
Speedo cable is in the middle between your intake manifold and the underhood fuse box, on the transmission. Right next to a mount. Held on by a 10mm bolt, take the c clip off to get the cable out. Don't lose the clip, you'll need it
if i were to take it out and examine it will it affect it if its good and i reinstall it?
if so can i test it to show me it works?
thanks
if you pull out the cable and reinstall it it will not do any harm. what you can do it take it out of the tranny and put a drilll on it and see if that makes your speedo move. if not your cable could be broken. if it does spin then the vss gear could be broken.
Location: I told you to wait in the truck in Texas, United States
There are some pics over here that may help you:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
{Down toward the bottom of thread...}
thanks man i was wondering where that dam cable was.
found it.
but cant seem to figure out whats wrong with it.
anyways my gf's uncle gnna check it out...FOR free.
love freebies.i swear. just makes the world a better place to know hookups.
hopefully i get it to work so i can grab me a 90 91 si cluster
BTW WTB 90 91 GAUGE CLUSTER W/ TACH.
thanks.
found it.
thanks.
i just had mine break, pull the actual cable out and check behind the clusterf, see if you got everything out. btw if you get a replacement from advanced auto you gotta replace the whole thing, cover and all. the new one is longer than the oem one so you cant just change the actual cable. automatics are longer too
found it.
thanks.
found it.
thanks.
its out today right after i get full license,i just turned 17 yesterday.
ima enlist airforce this saturday.HUA!
text me at 8087835185 if possible then ill give tracking number if they give me one.
ima ship it today i stalled for abit,cus iwanted to wait until you came back.sorry bro.
This is why I don't deal with shipping.
