GSR catch can or breather???
I am going to be installing a turbo on my stock motor 95' GSR, i am looking to make 300whp. Do I need a catch can or will a breather on the Valve cover work?
If I do need a catch can will this config work...
thanks for the help...
HELLO,GOOD MORNIN'
Re: GSR catch can or breather???
the way you have it setup is pretty much the way stock has it setup. I wouldnt run it that way. open it to the atmosphere. don't put it back into your intake.
Also remember that the smaller the opening is that's relieving pressure the more sources you need.
in otherwords get the correct size catch can
the valve cover should not see a vaccume. becuase in boost ovbiously you would be pressurizing it.
just vent the valve cover, and get a block breather system.
You bring up a good point..do you know of any good DIY block breather set ups, or will the breather on the valve cover be enough?
That configuration is not good. Get the endyn kit and be done with it. 2 fittins from the back of the block to a catch can that vents and you'll be good.
BWR on the sponsor market place under Forced induction selling them for 300. comes with AN lines fittings for back of block and for valve cover. good price on that. can look into that
HELLO,GOOD MORNIN'
migs
22
03-26-2008 05:23 PM
