which cams to get?
Old Dec 1, 2009 | 08:21 PM
eg:R's Avatar
Default which cams to get?
i was planning on getting a set of blox cams and i notice there are 2 type of stage ones. Which one should i get? there is a type 1 and a type A. i have ctr cams already but i plan to try something different. im planning to make 450-500 w/ a 30r.
Tuner Series
Type-A VTEC Camshafts
Honda B16A-B18C1-5 (1.6L-1.8L DOHC VTEC)
Intake (lift / duration)
0.462" / 247
Exhaust (lift / duration)
0.420" / 239
Tuner Series
Stage I VTEC Camshafts
11.9mm / 264
11.0mm / 259
Old Dec 2, 2009 | 06:14 AM
DA TeG 90's Avatar
Default Re: which cams to get?
Why dont you pick up some Blox Type B's? mad great power at lower boost and are in the same feild as skunk2 tuner series.
Old Dec 2, 2009 | 06:31 AM
eg:R's Avatar
i was thinking about that too, but i dont really want to risk any drop valves. which one will be better ,the type with a letter or the type with a number. with the hp goal that i want i might need to push a little over 20lbs. will the b's be a better choice?
Old Dec 2, 2009 | 07:56 AM
DA TeG 90's Avatar
Dont know too much about the a's. My brothers Turbo integra has blox type b's and loves them. Great powerband, and more power at low boost. Before he threw in GE cam gears and blox type b cams he had OEM b16/gsr. Made 411@17psi then with just type b cams it made 455whp @15PSI.
Old Dec 2, 2009 | 05:08 PM
eg:R's Avatar
you have his dyno sheet of before and after? so you mean he got the type b Competition one's right? not the tuners??
Old Dec 2, 2009 | 05:37 PM
project dc2's Avatar
tuners and competition have the same cam profile. the only difference is the lobe is wider ( think wider tires) for a better contact patch. performance HP wise no drastic differences.
Old Dec 2, 2009 | 05:56 PM
Turbo-LS's Avatar
Your HP goals are easily attainable on those ctrs, why bother with aftermarket cams when you can have OEM reliability and performance. IDK i just like oem for setups that arent just all out drag cars. yeah yeah i know you can make more power on same boost with an aftermarket cam setup i just dont see the need for them unless really wanting alot more power and a 3076 will do 450-500 easily on stock configuartion cams IMO
Old Dec 2, 2009 | 06:03 PM
eg:R's Avatar
which one do most people here use?
Old Dec 2, 2009 | 06:19 PM
TheShodan's Avatar
Moderator
OEM or skunk2 if the turbo is large enough.
Old Dec 2, 2009 | 06:26 PM
boosted hybrid's Avatar
We have been having really good results lately with the brian crower stage 2 and 3 cams FWIW. Picked up 10-15 whp over Pro 1's with some midrange loss on the stage 2's at 30 psi with an s366. The stage 3's wont lose anything midrange to the pro 1's, and will make even more power. After seeing 3 different customers break Pro 1's in a months time on the dyno I have been looking into other alternatives..
Old Dec 2, 2009 | 07:55 PM
in the last year I havent seen blox produce anymore competition cam lobes.
all cams that are in stock n that i've seen arrive are all tuner series. Quite possibly, there was no difference in performance or longevity/cam wear do they discontinued the competition series. Not said by Blox, but Since im there practically every week, I havent seen any competitions on shelf for a long time
Old Dec 2, 2009 | 11:41 PM
eg:R's Avatar
are the skunk stage 2 tuner the same as blox b?
Old Dec 3, 2009 | 04:04 AM
Turbo-LS's Avatar
What ever happend to the mazworx cams that alot of people used to run? they still in business or no? those were some nice cams
Old Dec 3, 2009 | 07:58 AM
similar
jdmsupreme2132
May 16, 2012 05:51 PM
komat
Sep 11, 2009 05:51 PM
JDMASTER EJ8
Jan 6, 2008 10:24 PM
