Gasket on dumptube?
Old Dec 5, 2009 | 10:28 AM
93grayeg's Avatar
Default Gasket on dumptube?
Hey guys just curious if I should run a gasket on my dump tube? im not running one on my wastegate. if anything should I just use some gasket maker ? or nothing at all?
Thanks
Old Dec 5, 2009 | 01:20 PM
93grayeg's Avatar
Default Re: Gasket on dumptube?
anyone?
Old Dec 5, 2009 | 02:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you dont have a v band, it ie beneficial to run one on the gate to manifold at the very least. if it dies leak there you will be down on boost, or it will lag more than it needs to.
you dont need one on the dump, but if there is anything in the way, it may get a little jet of hot air.
make sure it is clear all the way around.
Old Dec 5, 2009 | 02:25 PM
93grayeg's Avatar
ok thanks , I was under the impression I would be better off running no gasket on the wastegate to manifold? I have had bad luck in the past blowing gaskets, I am using a tial 38. . ?
Old Dec 5, 2009 | 02:38 PM
Mr. Badwrench
get a stamped metan gasket, not the fiber reinforced gasket. (the foil with the holes in it)
95dc2teg
Oct 19, 2006 03:22 AM
B16Civic93
Nov 24, 2005 05:17 AM
Rain_man
May 9, 2003 03:32 AM
Etylorcen
Feb 24, 2002 01:39 PM
D-SPEED
Dec 3, 2001 04:23 AM
