Finally got my car figured out: ITR with JRSC
This is my first supercharged car, ive always been an NA guy and this time i decided to do something different.
Mods:
STock OEM ITR Longblock (stock rods, pistons, etc)
Skunk2 PRO Valvesprings/Retainers
Skunk2 PRO Cam Gears
Skunk2 Stage 2 camshafts
KiddRACING Narrow B Header
JRSC 4.2in pulley
B20 Crank pulley
450cc injector
CTR Transmission with ATS 4.9 FD
The car made 200whp NA, ran into some problems with the supercharger holding boost because of the bigger "na" camshafts i had. SO i ended up just running more boost to solve the problem and it worked.
Making 5psi in VTEC i ended up with 233who/159tq. I hit around 9psi on low cam before VTEC , but once VTEC hit it drops down to around 5psi.
First impressions are the car is 100 times faster. The 4.9FD and the linear powerband , i dont know if there is much out there from stoplight to stoplight that could hang with it.
Ill get some videos and pics up later today.
Mods:
JRSC 4.2in pulley
B20 Crank pulley
450cc injector
Re: Finally got my car figured out: ITR with JRSC
Nice build. i would think tho you should be making more power with the supercharger on. only gaining 33hp with the supercharger doesnt seem right.. nice build tho.
FSAE
Good looking graph.
Did you for ***** and giggles dissable VTEC and see what the powerband looked like? Did you try advancing the exhaust cam at all?
I would definately opt for a smaller cam, at least on the exhaust side. Try a Skunk2 Stage1 exhaust cam or ITR exhaust cam.
Blow-through, FTL, Mike.
The best performing supercharged B-Series I have had come through here all had one thing in common: OEM GSR exhaust cam, ITR intake cam.
Supercharged cars can be pretty fun, though. I did enjoy my 320whp JRSC'd K20 for the 8 months or so before I turbocharged it. I miss being able to hold third/fourth gear like I could supercharged.
- Derek
- Derek
You could have gained quite a bit under the curve, and quite a bit of low end power.
It's not all about peak HP, it's about the power under the car, that's what makes the car go.
Good looking graph.
Heres JRSC "BLUE" vs ITR NA
In all fairness, the car made 200whp about 4-5 months ago. The last time i dynoed it NA was about a month before i did the supercharger it made 194whp (probably difference in humidity, etc).
so 233-194=39whp gain.
40whp from just 5psi, i can live with that. To be honest we tuned it very conservatively since this is a oem stock motor with less than 5000 miles on it. I was also only looking to make between 230-240whp i didnt want more than that so we stopped right there and made it safe to drive.
IATs were around 120-125 so thats good, but it is also in the 30s at night here haha. Summer time ill be doing the LHT manifold
As a long time jrsc fan and owner of 2 diff setups, You should be making much more than that with your pulley combination sir. Ive followed your threads in the past and enjoyed your work, so please dont think this is a hater reply. Your camshaft selection is killing you. Your pulley combo ( which = rotor speed and total cfm being moved) along with your decent mods and tuning hardware should be netting you in the 260+ range. Check out the 500+ page jrsc thread if you havnt already or hondatas old page with the jrsc dynos making 260+ with questionable bolt ons on b18c5s. As a competent mechanic who seems to be able to get his hands on good parts, try swapping ur cams for the tried and true gsr intake/itr exhaust combo. I gurantee you will not be disappointed. and in the meantime, enjoy ur new found low end tq!
But my dilemma is this:
The car made 197whp STOCK STOCK STOCK with just a header. I upgraded to Skunk2 Stage 2s and valvetrain (really just to rev higher and i got the cams for free) and made 201whp. It didnt make a ton of PEAK power but i was able to rev to 9500 safely and the cams shifted my power band about 700rpms (i was peaking at 7800 before, with the cams it was 8500).
Now, when i did the JRSC everyone told me to go back to stock cams. I kinda wrestled with the decision i wont lie. I would hate to put stock cams back in, lose 5-10whp, just to try an gain it back by the addition of 1-2psi if that makes sense.
You really think i would make MORE power going to a smaller cam?
I will say though that around here, most people with a JRSC on a semi stock motor make around 220-230whp seems i am right there, but with less boost. but you are talking about GSRs making 175whp, running 8-9psi making around 230whp , im making same power with 5psi
IMO your cams are for a Big all motor build. Throw a set of ITR's or even tuner1's in and i think you'll see a significant increase in power. to big of cams is overkill.. bigger always inst better. simple setups make the most.
Yes. Because it has less overlap. More overlap is great for a N/A engine but for a roots blown engine it's a killer. The M62 is not a compressor, it's a air pump. The increase in positive pressure comes from the supercharger ramming more and more air into a confined space. Your cam works against that theory, causing you to loose both boost and power by way of having more overlap.
I'd suggest going back to the stock cams or sourcing a dedicated cam for supercharged setups.
So IF there was a larger blower available the cams would help make the car more power as it would allow the engine to breathe better at higher revs.
Unfortunately at this time there isnt an off the shelf eaton kit that can support these cams ...its a matter of the blower being too small not the cams being too big IMO but either way it creates an issue as far as optiming a setup goes.
I think at 5psi the results speak loud....less boost, similar power...cams are working well. Blower = running out of lungs
There was that guy making that custom kit with the larger eaton unit though...his setup was pretty awesome and like 3XXwhp with an eaton unit on an older non K motor. Think the setup was gonna be mass produced eventually...300+whp with an eaton made for some sick torque lol
Nice numbers
which one felt faster, the all motor setup or the new SC?
Im assuimg these were in the same chassis?
I think i will switch back to my ITR cams and retune it , if nothing else just for another dyno graph and see where it helps/hurts. Be good info to know
I'd like to see a graph with the ITR's in just to see how everthing pans out in this thread haha. so many opinions. lets see what happens.
i say you will gain 10-15 hp easy by switching back to stock cams, your still flowing the same cfm of air, its almost like if you had a clogged cat on a supercharger, your boost would lower once you removed the clogged cat but your power will go up do to it flowing better, i know thats a bad anology but its the best i can do
I think its the fact that the blower is too small to flow his cfm
Nice numbers
Nice numbers
