FPR- CAR WONT START!!!!
Old Dec 4, 2009 | 03:46 AM
j.packsb's Avatar
Default FPR- CAR WONT START!!!!
so while i was reconnecting my charge piping that blew off, my friend unplugged the puel pressure regulator vacuum hose and forgot to put it back on. we tried to start the car about 3 times with it unplugged and idled terribley, would rev past 2k and was misfiring. so i plugged it back and let it sit over nite to let the flooded fuel drain, and this morning it was still doing the same thing. so i disconnected the battery and after a minute tried it again and not it wont start at all. it sounds like trying to start a car with a dead battery..? its a d16y8 on a chipped p28 with 450 cc injectors and walbro 255. anybody have any suggestions.?
Old Dec 4, 2009 | 03:53 AM
AutoSelectTuning's Avatar
Default Re: FPR- CAR WONT START!!!!
Well if the car sounds like the battery is dying when you crank it, Why dont you put a battery charger on it. Also check your plugs to see if they are fouled.
Old Dec 4, 2009 | 03:55 AM
j.packsb's Avatar
i doubt it was the battery. thats jus the only way i kno how to describe how it sounds. it turns over but sounds like its either not getting any fuel or no spark. im gonna check the plugs later after school and work. but it was running perfectly fine before. all itouch was the charge piping and that vacuum line...?
Old Dec 4, 2009 | 06:44 AM
j.packsb's Avatar
any help? i really need some advice asap. plz help if u have any suggestions
Old Dec 4, 2009 | 06:49 AM
azandford's Avatar
did you check the plugs yet? Sounds like they might be fouled
Old Dec 4, 2009 | 07:17 AM
j.packsb's Avatar
gonna check them when i get home. i dont see how it could be injectors if the car was runing and driving fine jus minutes before this.. must be plugs. it seems like the motor is definately getting fuel but no spark. before disconnecting the battery, it would start and idle from 200 to 600 rpms and go up and down. now after the battery unplugged, it wont start at all
Old Dec 4, 2009 | 07:25 AM
azandford's Avatar
not to beat this over the head but DEF sounds like plugs are fouled. I doubt its the injectors too, also make sure your plugs are gapped correctly
Old Dec 4, 2009 | 07:28 AM
j.packsb's Avatar
yea theyre gapped correctly. they worked fine before, but i jus put the kit on and theyre jus oem spec plugs so maybe they fouled under boost? i only drove it for about 5 mins before i noticed the boost leak from the charge piping..
Old Dec 4, 2009 | 07:33 AM
azandford's Avatar
what are you tuned with? Can you verify that FPR is working properly? Do you have a FP gauge?
Old Dec 4, 2009 | 07:34 AM
azandford's Avatar
i only asked about the gap because i had plugs that were incorrectly gapped but didnt show any signs of problem for 2 months and then the idle was low like yours around 200-600
Old Dec 4, 2009 | 07:37 AM
j.packsb's Avatar
im not tuned yet. i jus put the kit on last nite. im on a basemap for 450 cc injectors and low boost. ive had these plugs for about 8 months now. and now i dont know how to check if the FPR is working correctly. but i could smell a **** load of unburned fuel both in the cqar and the engine bay when it was misfiring. and no i dont have a FP guage
Old Dec 4, 2009 | 08:46 AM
89turboaccord's Avatar
Are the plugs gapped for stock or gapped for turbo?
If it's on only a base map don't go beating on it , base maps are ment to get you to the tuner or for you to get the car running and start the tune.
You knew that though. right?
do you have a wideband or anything to tune off of, besides reading plug's?
If not i'd get a few set's of plugs.
Old Dec 4, 2009 | 08:57 AM
j.packsb's Avatar
yes i kno a basemap is now supposed to be beat on but i need the car to run to get to my tuner. my tuner is going to use his wideband while he tunes. then i will soon be getting my own. no they werent gapped for turbo, they were gapped for stock. what should i gap them to for turbo?
Old Dec 4, 2009 | 09:34 AM
azandford's Avatar
Good gap for forced induction is .028-.030 . I run my ngk's at .030
Old Dec 4, 2009 | 09:36 AM
azandford's Avatar
did you just add the injectors? Also, do you have another good ecu?
Old Dec 4, 2009 | 09:59 AM
j.packsb's Avatar
yea the ecu is good. and yea i added the injectors to the basemap.. if thats wat u meant by that?
Old Dec 4, 2009 | 10:00 AM
azandford's Avatar
did you run the car with the injectors at all before the turbo kit was added? Are they new?
Old Dec 4, 2009 | 12:32 PM
i would guess the were just installed.
Old Dec 5, 2009 | 01:42 AM
j.packsb's Avatar
no i did not run the injectors before the turbo was addded but like i said i drove the car with them on already. it drove 2 nights ago witht them on and started numerous times with them on and idled just fine.
update- i pulled the plugs and they pitch black so the few times it did start, i was runnin real rich. put new plugs in, theyre all getting spark. charged the battery. motor cranks but doesnt start. fuel pump primes. what should i check next? i know its not my injectors cuz the car was running right before it all of a sudden stopped..?
Old Dec 5, 2009 | 10:28 AM
smoovy's Avatar
just a question but what 450cc injectors are you refering to? DSM? if so, Do you have a resistor box? sounds to me as injectors, map sensor and TPS will show symptoms of what your experiencing too. go back and check all your connections. sounds like something is loose
Old Dec 7, 2009 | 05:05 AM
j.packsb's Avatar
someone had accidentally kicked the ecu and the conversion harness came slightly unplugged. the injectors are dsm and yes i have a resistor box
Old Dec 7, 2009 | 05:32 AM
White Smoke's Avatar
i my honda
Global Mod
Glad you got it running... You need to change out your plugs asap though. You will want to go with a step colder plug for sure, along with a smaller gap.
Old Dec 7, 2009 | 08:20 AM
j.packsb's Avatar
already changed them to bkr's thanks for all the help guys
j.packsb
Dec 5, 2009 01:05 PM
j.packsb
Dec 5, 2009 01:40 AM
93gunner
Dec 14, 2007 05:05 AM
Syed Shah
May 29, 2007 10:03 AM
TurboTypeR98
May 27, 2002 08:26 PM
