boost+nitrous
Old Dec 22, 2009 | 11:58 AM
reddcoupe's Avatar
Default boost+nitrous
not sure if i am in the right sub-forum but hear goes my question is what size shot of nitrous is safe with 30psi of boost on cp pistons and eagle h-beam rods ready to tune but dont want to over do it and break engine too early
Old Dec 22, 2009 | 12:34 PM
10secb16's Avatar
Default Re: boost+nitrous
wet or dry ?
Old Dec 22, 2009 | 12:59 PM
reddcoupe's Avatar
Originally Posted by 10secb16
wet or dry ?
wet i learned my lession with the dry
Old Dec 22, 2009 | 02:19 PM
welfarepc's Avatar
nothing wrong with a dry shot.
you can run as much nitrous and your tuner is capable of tuning for, assuming you have enough fuel flow to keep things under control.
edit; i plan to direct port at least a 100 shot on my single cam, on top of a 10 second turbo setup.
Old Dec 23, 2009 | 09:05 AM
SOHCD16y8's Avatar
Nothing wrong with a dry shot, in fact I like the idea of controlling your fueling via the ecu per cylinder rather than a jet size. With that boost, spray as much as you want. I have a feeling you will run out of rod or fuel before you have to worry about anything else. Sleeved I assume?
Jeter2NYC
Jul 6, 2005 05:33 PM
sleeper95Lude
May 13, 2005 09:30 AM
1 Cam Wonder
Nov 26, 2004 11:30 AM
crxsirvtec
Aug 8, 2004 06:07 PM
Soccerking3000
May 19, 2004 06:56 AM
