Mac valve hookup confirmation 35A-AAA-DDBA-1BA
I need verification this is the correct way to hookup a Mac valve for S300 PWM with one end going to A11 and other end to 12V fused.
Re: Mac valve hookup confirmation 35A-AAA-DDBA-1BA
Can the positive side be tied to a 12v constant? i would think switched or constant shouldn't matter since the ecu is completing the circuit ?
I have mine running to a "hot Fuse" so is constant 12V but like you said it won't come on till the ignition is on.
will do, whats the easiest 12v switched source to tap into in the bay that is not a 12v switch from an existing sensor.
Mr. Badwrench
i took the canister purge solenoid, used the yellow black as the 12v sw, and then re pinned the other canister purge wire to a11
I'm planning on using the IAB since the evap purge is used even with OBD1 if im not mistaking without a CEL coming on
user 5743268
02-08-2017 07:31 AM
Dc4iNtEgRa
04-17-2008 10:55 AM
