fully built darton lsvt setup please help
Old Dec 11, 2009 | 05:42 PM
slowboyy06's Avatar
Default fully built darton lsvt setup please help
alright im mke this short and simple because i really need a fast answer, im have a sleeved ls darton block(82mm) with a stock type r head, im running with a the victorx for my im, and still undecided on the tb, where gonna be running with a turbonectics for my 35r turbo and probally a ram horn for my manifold, long story short i will have damn near everything you need to build a good running dd honda. my question is can i leave my r head stock and still make good power(360-450whp) or do i need to rebuild the head also
Old Dec 11, 2009 | 05:59 PM
YARO.'s Avatar
Default Re: fully built darton lsvt setup please help
Stock head will be just fine for that power goal revving to around 8500. I would upgrade the valve spring and retainers for anything over that. What is the ultimate power goal for this setup? What parts do you have already?
Old Dec 11, 2009 | 06:09 PM
slowboyy06's Avatar
i wanna be around 425-450whp dd
Old Dec 12, 2009 | 12:54 PM
B16Civic93's Avatar
i'd say that the head is fine for the power level goal. obviously anything you do will make it so its easier to reach the goal.. the better the head flows, the bigger the valves, is going to make a difference on the amount of air/fuel getting into the cylinders on each combustion stroke.
if your limited on the budget i would say your fine with the stock typer head.. like mentioned if it were my project i would change out the springs retainers and valves. i personally run the supertechs and i like them, rev to 8700. the type r head flows better then any other vtec head stock.
hope this helps
DrivinVtec
Oct 11, 2007 09:11 PM
WickedHonda00
Feb 28, 2007 08:55 AM
projectef
10
Jul 19, 2006 07:37 AM
erebunicrx
Jun 3, 2005 06:52 PM
95gsrturbo
Dec 7, 2004 07:18 PM
