Catch Can Install Help
Old Dec 12, 2009 | 10:07 AM
E85B18's Avatar
Default Catch Can Install Help
This is a picture of the underside of my B series valve cover. The top of the picture is the end facing the front of the car. You can see there is some sort of baffle there held on by 4 rivits or something. This is the side I want to install the two A-N fittings. Is there a problem drilling and welding on this side of the cover because of the baffle? Thanks
Old Dec 12, 2009 | 11:07 AM
accord_raffi's Avatar
Default Re: Catch Can Install Help
Isn't that the most common spot for the bungs usually? I don't see there being an issue
Old Dec 12, 2009 | 11:20 AM
90blackcrx's Avatar
Not an issue at all, drill and weld.
Old Dec 12, 2009 | 11:51 AM
jdm inc's Avatar
x2
Old Dec 12, 2009 | 01:16 PM
B16Civic93's Avatar
thats how i did mine.. just make sure you THOROUGHLY wash it out.. after i drilled both holes i rinsed it out with a hose, then i took it in the house and filled up my bathtub and rinsed it through that.. then took it back out and took a hose to it... any metal shavings left inside of it could cause complete distruction to your engine.. and i'm sure you dont want that. hope this helps
Old Dec 12, 2009 | 03:56 PM
E85B18's Avatar
Cool. Thanks a lot for the info and advice! I didnt think it would be an issue since so many people weld it there, I just wanted to make sure.
Old Dec 12, 2009 | 04:25 PM
Atreidies's Avatar
Most people drill vents there BECAUSE of the baffle. It helps make sure you only vent vapor, and not liquid oil that could get flung up there by the rockers/cams.
Old Dec 12, 2009 | 04:27 PM
turbociv910's Avatar
Old Dec 12, 2009 | 05:17 PM
cjordan's Avatar
thats the exact reason mine is done that way
Old Dec 12, 2009 | 07:34 PM
E85B18's Avatar
Interesting! Makes sense. Thanks guys, great info
Old Dec 13, 2009 | 10:02 AM
IN VTEC's Avatar
Use a shortened 1/4" pilot drill on a hole saw to avoid drilling through the baffle. Also, if you have a ramhorn manifold, the -12AN plumbing may have some interference with the manifold; -10AN should work fine though. (taken from my personal experience using -12AN ports with a Full-Race Prostreet manifold).
Old Dec 15, 2009 | 04:10 PM
E85B18's Avatar
Thanks for the advice. Luckily I have -10 fittings. I'm going to drill and weld this weekend
JavierD16
Jul 5, 2018 05:53 AM
sikwitit
Apr 29, 2006 10:56 AM
Supraznki
Apr 12, 2005 03:18 AM
Lei Siew Long
Feb 9, 2002 10:05 AM
Integra187
Jun 22, 2001 11:32 AM
