Turbo d series question
Old Dec 10, 2009 | 10:45 PM
Dual Cam Killer's Avatar
Default Turbo d series question
Ok, I turboed my ef. But i wanted to ask if it is true that oil return lines have pressure behind them as well as the oil feed? Reason being that i hope there is, is because my return line is just a tad bit too long, so the oil must travel down, slightly up, and then into the pan. Will this cause oil to backup into the turbo forcing the oil to push thru the seals? Any positive feedback is greatly apreciated.
Old Dec 11, 2009 | 10:26 AM
delinquent's Avatar
Default Re: Turbo d series question
https://honda-tech.com/forums/forumdisplay.php?f=16
Old Dec 11, 2009 | 10:59 AM
ian1006's Avatar
Should be a straight shot, the oil should not have to go up before the oil pan...just shorten it, not hard to do.
Old Dec 11, 2009 | 11:38 AM
I did shorten it, but the way my turbo manifold is, the drain fitting on the turbo is about 1 1/2 inches above the fitting on the oil pan. so there is no way to make it just come from the turbo to the oil pan, because the fitting on the oil pan is about 2 inches to the left of the turbo fitting. So i shortened it, as much as i could, but there is still a slight incline the oil must travel. Is this going to be safe or will the oil backup into the turbo? thanks a bunch fellas.
Old Dec 11, 2009 | 12:04 PM
Vagitarian's Avatar
As long as the turbo fitting is above the oil pan, you should be able to make it drain on a downward angle
The return isnt pressurized, and if your making oil go uphill you may be looking at serious turbo trouble
Old Dec 11, 2009 | 01:31 PM
brutekiller787's Avatar
you are gonna blow seals. are you using an HF manifold?
Old Dec 12, 2009 | 06:37 AM
no, ive got a ram horn turbo mani, and yea blowin seals is what im affraid of. I just got done foolin with it. I think its gonna be ok, it looks pretty level.
swatteamtimmah
May 7, 2006 04:19 PM
MBlake55
Feb 27, 2006 10:18 AM
TEG777
Aug 18, 2005 09:38 PM
Weston
Jan 26, 2003 01:37 AM
cokex
Oct 17, 2002 01:09 PM
