building h22a for turbo questions!!!
ok heres the deal! i got a 95 eg coupe with already done h22a swap. and its stock n/a right now im running hondata s300 with a tune from beyond redline, greenbay, wi. i heard alot of good stuff bout the mahle gold series pistons safe for the frm sleeves msrp $600.00... my set power id like to make is 400whp i think thats a good pwr to weight ratio for an eg oh yeah currently my car weights 2300lbs. right now im running 14's on the strip. well what i wanna know is could my stock rods hold up 400whp? and would the frm sleeves hold that much pwr? i heard frm is stronger than iron? im gonna be running a t3/t4 setup or a mitsu 16g setup.... watcha guys think more info the better thanks!!!!
Re: building h22a for turbo questions!!!
why is that a no go on the 16g setup???? what do u think i should run taking in consideration of my limited funds?
You can make 400whp but 350whp would last longer on a stock engine but you need to do a few things,like a .080tho cometic hg and arp headstuds.oh yah and scrap the 16g idea and put a real turbo kit on there.Im selling my h22 full turbokit that fits into eg chassis for cheap pm me for details.
i heard the frm sleeves are stronger than mild darton sleeves. plus its a h22a its closed deck?
Depends on the series h22 you have. We have made well over 500hp on 100% stock motors with .030 cometic and good headstuds depending on the fuel and tune on obd1 closed deck blocks. So far, with an open deck obd2 we are yet to push it that far because we have been waiting for aem to send our cdi back, but we are over 400hp so far and only has .030hg and headstuds. I plan on shooting for much more when it's ready. with stock headbolts and hg it blew immediately at 400.
Big thing is Turbo setup and Tune. a cheap turbo kit and sh*t turbo will only get you too much boost with a hot charge and detonation. Peakboosts work great and are proven around here. Otherwise, H22 is very similar to a k20 in terms of flow.
You are correct greencivic, the h22 FRM cylinder walls are very strong however, thats not what you should be worried about. You need to be aware of the weak piston ringlands. Also the rods seem to go out after pushing it past 400whp.
yeah i figured that cuz thats why i went with the h22 cuz of the strength of the frm sleeves and the high tq.... i have a closed deck too which makes it even better!!! any body got a good idea of what kind of turbo i should run id like to keep it under 800 bucks!!! thanks for all the info guys anymore of what u think i should do with my setup would be appreciated.....
for 400whp this works: http://cheapturbo.stores.yahoo.net/gat357trw63a.html
Get a billet wheel, get a 5557. The stock rods would probably hold it because they are pretty beefy. But id just find a set of eagles. Thats what i run in mine with wiseco pistons.
nigel
10-02-2003 08:42 AM
