is blox any good for f/i ???
i have my build almost done, i just need a few thing like cams and springs and cam gears i was think of going with BLOX's but i keep hear that there no good its like riding on stock parts... i know skunk2 and brian crower are one of the top of line parts to get when you going with a F/I build, but those parts are worth a bit to much, now that i spent most of the money sleeving the block and getting pistons and rods for it and porting the head,
but what do you think about bloxs?????? in 1-10
Re: is blox any good for f/i ???
you'd probably be fine, but if you're spending tons of money on the motor anyways, why cheap out on something important? i would trust stock cams over those.
i've been using blox cams for a few years with no issues. and i don't think i can recall in the many years blox has been around that i have heard of any of their valve springs/retainers failing....at least no more than any other brand.
for the price their stuff will work just fine. you wont have any issues with them as long as they are installed correctly.
Dose anyone know if the Blox HSL would work ok for boost?
also I think Edynes bump stix are the same as Blox comp c's
I was looking at the blox comp C camshafts and the measurements seem to be the same as Edynes bump stix I looked at Edynes website for measurements http://www.theoldone.com/components/...n_Camshaft.htm
and searched for the blox comp c mid page
http://nwp4life.zeroforum.com/zeroth...postid=1169702
intake lift 12.2mm = .481" duration 268 @1mm
exhuast lift 11.6mm = .458" duration 264 @1mm
I also used a inch to mm calculator at www.industrial-enclosures.com to compair
if I am wrong please let me know thanks
cool thanks guys, non-VTEC its good to see that some one has gotten good resalts out of bloxs and im going to upgrade the valvetrain
thanks for the info guys
ls/vtec
cp flat tops
eagle rods
full race exhaust manifold
edelbrok intake manifold
68mm trotle body
blox b cams
3"intercooler piping all around
3"downpipe2.5"exhaust(after downpipe)
supertech valve springs and retainers
stock port gsr head
t3/t4oe 63 ar 57 trim
hondata s300
1000cc injectors
cp flat tops
eagle rods
68mm trotle body
blox b cams
stock port gsr head
hondata s300
1000cc injectors
gsr block
eagel pistons and rods
2 1/2 full racing exhaust
skunk2 IM
68mm HAD throtle body
aem fuel rail
255 walbro feul pump
1200 RC injectors
ARP head studs
rb25 i think thats what my brother said it was
top mount manifold
b16a3 head ported
just orded buddy club valves and
skunk2 cam gears
im going for 450 hp if more that'll be great
skunk2 IM
aem fuel rail
1200 RC injectors
ARP head studs
top mount manifold
b16a3 head ported
skunk2 cam gears
