ram horn question
Old Dec 20, 2009 | 07:59 PM
cadeMFjohnson's Avatar
Default ram horn question
http://cgi.ebay.com/ebaymotors/HONDA...item5ad5b44fbd
look at the pictures in the above link. now, im not thinking of buying this, as its cheaply made and not the correct flange, BUT it shows you what i need you to see. notice there's what appears to be like a downpipe flange or something on the front of the manifold. why is this? i obviously haven't looked much at ram horns before, is this common? explain what the hell this is and how it works
Old Dec 20, 2009 | 08:24 PM
dragonjay006's Avatar
Default Re: ram horn question
All that is in the front is the wastegate flange, yes its common on ram horn mani but some wastegates use differant flanges
hope this helps
Old Dec 24, 2009 | 09:33 PM
i realize how dumb that question sounded. so do they make ramhorns for an internal wastegate, or would this just be a waste, and not necessary for a turbo running an internal wastegate (usually lower boost)
or has anyone ever just blocked off this wastegate port and used it with an internally wastegated turbo
Old Dec 24, 2009 | 10:03 PM
thumper64's Avatar
You can use the manifold with a turbo that has an internal waste gate by using a block off plate. There's not too much reason to.
And those manifolds aren't that bad. Rick Rabies had one and it held up fine at like 10lbs boost, it spooled the turbo quick. It's certainly not the best, but it's not complete garbage either.
Old Dec 26, 2009 | 06:18 PM
word. yea its been on my car for about 5000 miles on ten lbs. no problems thus far.
thinkin of goin with a bigger turbo still internally wastegated i assume, (16g mitsu turbo)
and about 18 psi. after rods and pistons are in
Old Dec 26, 2009 | 11:01 PM
thumper64's Avatar
You'd probably make more power on a T3/T4 with lower boost. An externally waste gated turbo will perform better, internal is just cheaper to do.
Old Dec 29, 2009 | 03:58 PM
cheaps the way i gotta go
homicydalboy
Jun 4, 2007 06:12 PM
Mr. Vapor
Welding / Fabrication
12
Feb 10, 2006 02:36 PM
16vt
May 6, 2005 06:14 AM
DriveSlowHomie
Apr 19, 2005 02:04 PM
J337_UNIT
Feb 17, 2004 09:41 PM
