E-Cutout
Old Dec 21, 2009 | 04:28 AM
rudebwoy's Avatar
Default E-Cutout
anyone run a exhaust cutout before the o2 sensor, my o2 sensor is located behing the engine before the cat, but because of limited space and to make it most effective I plan to put the cutout in front of the engine off the topmount downpipe and dump it right next to the wastegate dump. will this be a problem? the motor will be tuned with the exhaust closed, but I figure we will have to tune a little richer to compensate for when its open.
Old Dec 22, 2009 | 11:17 AM
rudebwoy's Avatar
Default Re: E-Cutout
anyone?
at least please show some pics of setups.
Old Dec 22, 2009 | 12:40 PM
NonovUrbizniz's Avatar
Loved
Your o2 will not get readings if the cutout is before it.
You will need to retune for the cutout being open which will be hard due to no o2.
Old Dec 22, 2009 | 01:38 PM
rudebwoy's Avatar
I am thinking should just to add another bung before the cutout which could be use for tuning with the coutout open only, since I cannot run 2 wideband o2 daily, but one concern I have is the o2 sensor that is located before the cutout will either get too much oxygen from being too close to the opening, or burn up too quick from being too close to the turbo. but this would be used only during tuning so it may be a short term issue.
Old Dec 24, 2009 | 11:36 AM
rudebwoy's Avatar
bump
accordfreak
Feb 22, 2011 08:34 PM
88 EF Hatch
Engine Management and Tuning
Sep 23, 2009 07:23 PM
92HB_HB
May 11, 2005 06:06 AM
opto_isolator
Mar 27, 2004 05:37 PM
