Which 84mm Piston ring set to go with?
Old Dec 20, 2009 | 07:04 PM
95dc2teg's Avatar
Default Which 84mm Piston ring set to go with?
I am freshening up my block and have a set of 84mm CP 9.0:1 compression pistons. I was going to go with CP pistons rings, but I was wondering are there any alternatives? Any other good brands that I should look into? Thanks!
Old Dec 20, 2009 | 08:26 PM
95dc2teg's Avatar
Default Re: Which 84mm Piston ring set to go with?
ttt
Old Dec 20, 2009 | 08:49 PM
king06's Avatar
You can also use Total Seal.
Old Dec 20, 2009 | 08:53 PM
locash's Avatar
I'd recommend sticking with the CP rings.
Old Dec 21, 2009 | 07:30 AM
miguel329's Avatar
^ same here
Old Dec 21, 2009 | 07:03 PM
TheShodan's Avatar
Moderator
Best to use what was designed for the piston. Total Seal could work if you want to if you have an unknown piston or one of a truly custom configuration, but its best to just use what you have with the piston
Old Dec 21, 2009 | 07:08 PM
95dc2teg's Avatar
alrighty just what i figured. I was going to go with them anyways, but never hurts to know if there are alternatives. Thanks for the replys guys. CP rings it is!
blackeg
Mar 11, 2013 03:16 AM
95blackEG
May 23, 2007 02:50 PM
the g2 teg
Apr 25, 2006 01:30 PM
DC2TT
Jan 9, 2006 07:47 PM
int3gra
May 23, 2002 03:30 PM
