Highest hp on 91oct with "saftey" in mind?
What would you guys say is the hp limit for 91 octane. My car is driven almost every day, and obviously i would like to get the most out of it i can/should on 91pump.
quick run down on set up:
84mm ls/v
stock b16 head
little t3/t4
1000 ID's
255 walbro
s300 w/boost by gear
PLX m300 wideband
Im curious as to what the HT crowd is doing day to day.
Thanks.
84mm ls/v
stock b16 head
little t3/t4
1000 ID's
255 walbro
PLX m300 wideband
Thanks.
Re: Highest hp on 91oct with "saftey" in mind?
compression ratio? manifold design efficiency? injector? tune? all those play a huge factor in making power on pump gas as well.
91? you poor bastard. I guess I could start appreciating the 94 thats everywhere around here. I can't see why 400-450 isn't "do-able" on a good tune.
stefan from ASP http://www.advancedstreetperformance.com/ made over 630whp on pump gas like 4 years ago
just for reliability i would try and keep it around 450hp or so not saying more can't be made but i would try and keep it as safe as possible and either way your tuner better be good
x2. Be sure to get a good tune and it will last. You could consider adding a meth kit to up the boost a bit, either way 630whp on 91 octane is not a good idea
i was looking into the AEM Meth kit.
I would like to go the E85 route, but we only have 2 or 3 stations that carry it in town. You'd think the largest city in Kansas would be loaded with the stuff.
Dude if you have the option, run E85! 3 in your town?? I had to drive to the next town for gas when I ran E85.
radeon
24
12-30-2004 12:32 PM
