Whit smoke low comp
Old Dec 13, 2009 | 01:03 PM
avotegra's Avatar
Default Whit smoke low comp
smash on 3rd gear, now the car sound like a subaru and cylinder close to dizzy is 0 compression. all other are still 200psi. white smoke. oil in coolant and coolant in oil.
is this a sign of blown headgasket.
Old Dec 13, 2009 | 01:05 PM
Eran's Avatar
HT White Ops
Default Re: Whit smoke low comp
These are the exact symptoms of a blown head gasket. A simple search would have yielded you this information.
Old Dec 13, 2009 | 01:28 PM
avotegra's Avatar
i did search but most of them still have compression, my clyinder close to dizzy has no compression, did a wet test with oil still no compression. sure this is blow gasket. if it is should it have at lest a little compression .
Old Dec 13, 2009 | 01:31 PM
Eran's Avatar
HT White Ops
If you have oil in your coolant, and coolant in your oil ... it probably is a head gasket. Unless you blew a hole in your block.
Old Dec 13, 2009 | 03:55 PM
boostek9's Avatar
HG, coolant in cyl. causes white smoke, time for a boost build, lol
Old Dec 13, 2009 | 05:22 PM
cjordan's Avatar
either way it sounds like the head needs to come off... you will know if you have a hole on your piston, sunk sleeve, warped head, or whatever else when you get it cracked open. 0 compression would lead me to think worse than just a headgasdket
Old Dec 13, 2009 | 11:34 PM
avotegra's Avatar
that what iam thinking 0 compression is scary me. hopefully its only a headgasket....
Old Dec 13, 2009 | 11:45 PM
Joseph Davis's Avatar
I think you have headgasket and piston damage. I've seen huge sections of headgasket blown out in Honda applications, pushed out the back of the block in DSMs, and still have some compression although it's super low.
toeKNEEohh
Oct 27, 2012 09:44 AM
Red-Rag-B18
Aug 23, 2010 05:33 PM
UserX826
10
Oct 29, 2008 12:00 PM
an2ny888
Jul 4, 2008 07:40 AM
97itr86
Oct 30, 2004 08:51 AM
