TIAL V44 Questin?????
Old Dec 7, 2009 | 05:56 PM
ludatic98's Avatar
Icon2 TIAL V44 Questin?????
i have the tial V44 wastegate on my boosted h22.
my question is should it be releasing exhaust at an idle with and without the vaccuum hooked up?
or should it be sealed up until it creates enough boost to open the spring?
Old Dec 7, 2009 | 06:04 PM
hybrdthry911's Avatar
Default Re: TIAL V44 Questin?????
should be sealed if its not make sure the fire ring is properly installed.
Old Dec 7, 2009 | 06:10 PM
ludatic98's Avatar
Thats what i was thinking, i opened it once to check the spring size before installing it, so there maybe something wrong i guess...
it will still work like it is but i think if i fix it, it will get rid or some of my boost lag for sure..
thankd anymore insite would be great...
Old Dec 7, 2009 | 06:19 PM
do you know what the fire ring is?
it is a ring that goes between the wastegate valve and wastegate body where it meets the manifold flange. it is a seperate piece that can come out, or depending on where you got it some shady dealers manage to not include it with the wastegate and try to charge you for it later.
Old Dec 7, 2009 | 06:25 PM
GT35R_EF's Avatar
Make mine whatever you want
This ^ I lost mine for the longest time before I assembled everything. It should have come taped to the the bottom of the wastegate.
Old Dec 7, 2009 | 08:07 PM
ludatic98's Avatar
So if this is what i need to fix my problem then where can i get one?
Old Dec 7, 2009 | 10:18 PM
TheShodan's Avatar
Moderator
You would call TiAL direct for that.
Old Dec 8, 2009 | 04:16 AM
TiAL's Avatar
negative, you would call the distributor that sold it to you and bitch up a storm if you bought it new and it didn't come with one.
if you lost it, contact a distributor and they can get you taken care of
Old Dec 8, 2009 | 05:18 AM
dpetro1's Avatar
isnt the v44 a v-band connection? do they still have the fire ring? i thought that was for bolt-on 38mm only.
EDIT: looks like they do have one after all.
Old Dec 8, 2009 | 08:17 AM
ludatic98's Avatar
thanks for all the info, im gonna pull it off this evening and see if they tried to stick it to me, ill keep you updated
thanks again
Old Dec 8, 2009 | 08:34 AM
TheShodan's Avatar
Moderator
IF he didn't have a dealer, you DO have a list of them, correct? Don't act like that dawg..
flangemastermike
Jun 13, 2007 04:46 AM
D16SohcVtec
Jul 20, 2006 04:07 PM
Turbo_Mike
Jul 14, 2005 12:07 PM
Nextelbuddy
Oct 13, 2003 08:14 PM
PureTeg420
Dec 24, 2001 02:27 PM
