Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
I need some info on diameter of ls/b16/gsr crank journals.
Old 12-16-2009, 07:51 PM
GSR_hatch936's Avatar
Default I need some info on diameter of ls/b16/gsr crank journals.
Like the titles says if anyone has a print out sheet with the main journals and rod journals for these motors I would really like this info.! Thanks in advance.
I tried this in a different section and didnt get any respond.. So anyone with this info please chime in!! or direct me to a better direction where i could find this information.
GSR_hatch936 is offline
Old 12-17-2009, 12:19 PM
Default Re: I need some info on diameter of ls/b16/gsr crank journals.
I need his info asap!
Old 12-17-2009, 12:53 PM
http://www.aclperformance.com.au/us/...rings_crus.htm
Click on the bearings for the motor you want and it will tell you the min and max crank journal sizes.
PrecisionPerformanceParts is offline
Old 12-17-2009, 05:12 PM
Thanks sooo much bro
Old 12-17-2009, 05:50 PM
One more question,,, is tha the inside diameter of the bearings or the outside diameter of the journals?..
Old 12-17-2009, 08:50 PM
Acura/Honda B16A2, B16A3, B17A1, B18A1, B18B1, B20B, B20Z Engine Bearings
YOU ARE HERE: ENGINES/VEHICLES > HONDA >B16A2/B16A3 B17A1 B18A1*B18B1 B20B B20Z > ENGINE BEARINGS
*ENGINE BEARINGS
CON ROD BEARING SET
MAIN BEARING SET
Part# Part#
4B1946H
4B1946HX
* 5M1959H
* 5M1959HX
Sizes STD, 025, .25 STD STD, 025, .25 STD
Oil Clearance Standard + 0.001" Extra Standard + 0.001" Extra
Half Type Identical Halves Upper & Lower
Material
Tri-metal Hardened steel backs
Tri-Metal
Min Std Shaft Size
1.7709" / 44.980mm
2.1646" / 54.980mm
Max Std Shaft Size
1.7717" / 45.000mm
2.1654" / 55.000mm
Min Std Tunnel Size
1.8898" / 48.000mm
2.3228" / 59.000mm
Max Std Tunnel Size
1.8907" / 48.024mm
2.3236" / 59.020mm
Max Wall at Crown
0.0592" / 1.504mm
0.0587" /1.491mm
0.0790" / 2.007mm
0.0785" /1.994mm
Max Overall Length
0.768" / 19.50mm
0.787" / 20.00mm
Old 12-18-2009, 07:03 AM
Shaft size is the crank size, just like you would measure with a micrometer on the journal.
Old 12-18-2009, 07:34 AM
pettyboy69's Avatar
next time post this in the right section, crank journals have nothing to do with forced induction and if you post in the right section you will get info faster.
pettyboy69 is offline
Old 12-18-2009, 09:10 AM
Ok I guess reading owns you and yes I did post in the right section at first but got no respond as I posted above so if you got no input about what the title say Gtfo! Damn why do ppl wanna act like moderators on fourms?!!!
RiPe14yoU
05-16-2017 02:44 PM
Dunc
General Discussion and Debate
01-13-2017 05:44 AM
2kdrift
11-10-2015 08:02 AM
Nickyd
Northern California (Sales)
14
06-02-2015 09:47 AM
jasondok
09-12-2006 07:43 AM
Quick Reply: I need some info on diameter of ls/b16/gsr crank journals.
  • Ask a Question
Question Title:
Description:
