turbine?
ay guys! so i just bought a t3/t4 turbo from a friend of mine that he had on his e.g. hatch and i was cleaning it up yesterday and i notice that the turbine has a lil play. now my question is, is the turbine suppose to have play? thanks!
mine has just a little of play... basically just enough to feel it move.... when it was new it felt like it had Zero play but after putting a few hundred miles on it you could tell that it moves just a bit....
the wheels will always have slight play. whether it touches the housing or not is the key indicator if the turbo is totally busted n worn out. the blades should NOT touch or scrape the housing when you spin it. and it should not have a lot of thrust play ( side to side movement)
em1gangsta
Texas -OK -LA (Sales)
Mar 27, 2013 12:12 PM
