Identify this turbo, please!
Old Dec 20, 2009 | 07:45 AM
TylerB's Avatar
Default Identify this turbo, please!
Identify this Garrett Turbo please.
Oil and water cooled.
Turbine:
.48 A/R
Internal Wastegate
Standard T3 Flange
Standard 5 bolt downpipe
Exducer : 2.295" (58.31mm)
Inducer : 1.092" (48.48mm)
Compressor:
No A/R stamp
2" Inside Inlet
1 3/8" Inside Outlet
Exducer : 2.368" (60.14mm)
Inducer : 1.667" (42.37mm)
I can give pictures if needed.
Thanks!
Old Dec 20, 2009 | 07:57 AM
TheShodan's Avatar
Moderator
Default Re: Identify this turbo, please!
there are a couple of 5 bolt flanges. Do you know where you got this from? You have inducer /exducer backwards for the turbine, which makes it a little difficult to determine
That is easy in the smaller GT25 range. takes a minute to figure out what turbine wheel you have. But needless to say its rather small, that is why I ask where you got it from or off of What... Pics would help please.
Old Dec 20, 2009 | 08:56 AM
TylerB's Avatar
Forgive me for the measurements, I got my measurements by following this diagram:
The measurements were correct but I wasnt aware they fliped on the turbine side. So the correct way should be:
Compressor:
Turbine
Inducer: 2.295" (58.31mm)
Exducer: 1.092" (48.48mm)
I'm selling this for a friend so I am not sure what it came off of, I hope the pictures help. They are not the best pictures, sorry, they are from my blackberry. Thanks again.
Old Dec 20, 2009 | 09:00 PM
TylerB's Avatar
Bump
Old Dec 20, 2009 | 09:04 PM
91jdmhatchback's Avatar
looks like a .42/.48 a/r T3 Garrett, with the ford style 5 bolt.
Old Dec 21, 2009 | 05:49 AM
TheShodan's Avatar
Moderator
Definately a smaller SAAB / Volvo OEM application. Smaller than a stage I turbine wheel, with an inducer that is in a GT22-GT25R range. Not sure of exact measurements of the SAAB (there were quite a few in the early 2000-2005. It's made for an internal gate. Power output is MAYBE 30lbs/min Maximum. that's under 150whp capability. He may have to search a bit more as to a p/n on the cartridge or serial number to compare, but I'd say that's an OEM application. Not sure from what though. Looks like a T25 flanging system as well. but need to have a better look at the exhaust inlet flange
My_EFsedan
Sep 27, 2011 10:15 PM
JD95hatch
Oct 14, 2004 01:23 PM
s1ngle
Oct 4, 2004 01:57 PM
civictypenos
May 11, 2003 03:59 AM
95 LS
Apr 16, 2002 05:18 AM
