License plate with intercooler
Old Dec 21, 2009 | 05:05 PM
SkyliteCustomz's Avatar
Default License plate with intercooler
Searched, but couldnt really find a definite answer..Will mounting my front license plate in front of my FMIC hinder anything performance (i.e. block significant airflow to the intercooler) wise? I just don't feel like getting harassed for no front plate
Old Dec 21, 2009 | 05:13 PM
GinsterVRT's Avatar
Default Re: License plate with intercooler
Just mount it to the side. I don't think it will hurt anything though
Old Dec 21, 2009 | 05:37 PM
that's what i was thinkin..wouldnt the air just flow around the license plate
Old Dec 21, 2009 | 06:21 PM
GinsterVRT's Avatar
Yeah, unless ints right up against it.
Old Dec 22, 2009 | 01:52 AM
yea, i think i'll go try it and see what happens
Old Dec 22, 2009 | 05:11 AM
b20beast83's Avatar
it would affect cooling if directly infront
Old Dec 22, 2009 | 05:40 AM
Boosted-EH-804's Avatar
I put mine off to the side and how big is your IC
Old Dec 22, 2009 | 01:09 PM
i've been seeing alot of mixed responses so im going to just see for myself
Old Dec 22, 2009 | 01:11 PM
Intercooler Size - Thickness: 2 1/2", Length 27", 5.5" Height, 2.5 " inlet, 2.5 " Outlet
Old Dec 22, 2009 | 02:03 PM
Turbo-LS's Avatar
its a small intercooler and if its not a quality piece then it might be an issue but it also depens on how much boost your going to run and what size turbo. if your running a small turbo and trying to crank the boost then intake temps are going to get high if the intercooler isnt working 100%
Old Dec 22, 2009 | 03:49 PM
It is rather small you should be ok and should not have any cooling issues either. I didnt have any when I ran the smaller IC but when I started upgrading to bigger ones damn did that block flow to my RAD
Old Dec 22, 2009 | 04:33 PM
my turbo is small and i'm bosstin about 7psi daily driven. i just put on the license plate back on. imma see how the car runs for a couple of days and if i notice any significant change. Thanks for all the replies
Old Dec 23, 2009 | 03:44 AM
Turbo-LS's Avatar
you wont notice change just put the plate on your fine
Old Dec 23, 2009 | 03:53 AM
yea i actually didnt notice any change at alll..even did a couple of runs today, still pulls like a motherf**
Old Dec 23, 2009 | 08:24 AM
accord_raffi's Avatar
This may be silly but did you touch your cold side charge pipes to see if they were any warmer after a pull now that you have a license plate in the way?
Old Dec 23, 2009 | 12:04 PM
Turbo-LS's Avatar
on 7 psi there isnt going to be much heat generated so there probably wont be a noticable difference to the touch
Old Dec 23, 2009 | 01:11 PM
THEUSED's Avatar
You would have to atleast use a infared temp gun to know for sure, unless your hand is a thermometer
Old Dec 23, 2009 | 03:48 PM
E85B18's Avatar
I took mine off because of high temps and got a ticket so I had to put it back on. F*** the police!
Old Dec 23, 2009 | 06:57 PM
high temps? i dont kno, i havent noticed any difference so i'll just leave the license plate on..better than a ticker
melovesboost
Apr 8, 2007 05:59 PM
ladysman
Sep 17, 2005 11:00 AM
WH0R3nEF9
Mar 28, 2005 06:58 PM
EVOCELICA
Apr 14, 2003 11:39 AM
SiRkid
Jun 4, 2002 04:15 PM
