Pump gas
Old Dec 10, 2009 | 05:41 PM
Random@**Hero's Avatar
Default Pump gas
Trying to see what everyone makes on pump gas and on what kind of setup:
B18c1 9:1 85mm
ctr cams
custom top mount and 4" dp
Custom made Bullseye S368 (thanks david)
on 93 octane at 18.5 lbs car made 532 whp misfiring with a weak coil.
Old Dec 12, 2009 | 01:05 PM
B16Civic93's Avatar
Default Re: Pump gas
pretty good numbers.. i take it you ahve a sleeved block
Old Dec 12, 2009 | 01:28 PM
Oh yea. Not sleeving a block is just a dumb idea
Old Dec 12, 2009 | 05:06 PM
nos487's Avatar
What kind of fuel system you running? Good numbers!
Old Dec 12, 2009 | 07:18 PM
just some 1000cc's and regular dime a dozen walbro 255 high pressure
Old Dec 13, 2009 | 07:09 AM
boostedEF91's Avatar
why is having a non sleeved block a dumb idea. It's all a preference to what power you want and the reliability issue.. I've seen numbers just as high as you without sleeves. on pump. and have lasted very long. its just a fun challenge to see how far a non sleeved block can go...i mean its easy to make what you made with a sleeved block..
Old Dec 13, 2009 | 07:27 AM
I just dont see a point in throwing away a motor for a d$ck measuring contest on who makes more unsleeved when you can just spend 1k extra for peace of mind. 1k is cheaper then motor shavings gong through a $1,400 turbo.
Old Dec 13, 2009 | 11:04 AM
when a motor blows it doesn't necessarily always throw shavings into the turbo... and as for throwing away a motor some have money to play with so its no biggie.. as for this thread where is it going.. all you have to do is search. everyone posts there setups. you just have to look.. end of thread.
Old Dec 13, 2009 | 11:17 AM
No one forced you to post in here.
Old Dec 13, 2009 | 11:35 AM
ouch. and yes i am new to honda stuff. always had v8's.
Old Dec 13, 2009 | 11:38 AM
well then your New to honda-tech.. and dont know how things work on here.
Old Dec 13, 2009 | 12:12 PM
eg:R's Avatar
what is everyone target or safe a/f on pump gas with 400+ hp? is everyone still running 11.8 range or is everyone running a bit rich to be on the safe side??
Old Dec 13, 2009 | 05:43 PM
Tony the Tiger's Avatar
Well said... I've seen too many stock sleeved builds with really NICE and BIG turbos (42R's, etc.. over $2000). The mindset of thinking "yeah, I'll see how far I can push the stock sleeves, and then I'll upgrade later" often means "I will throw everything I currently have in the trash when I blow it up"
A cracked sleeve, or a sleeve that is hairline cracked will leak coolant into the oiling system. A couple of hard runs would dilute the oil enough to really f*ck up the rod and main bearings and enough to damage the turbo from all the bearing debris in the oiling system. Coolant contamination could also starve the turbo from proper oiling. If you are lucky, the sleeves would crack right away and damage may be minimal. In many cases, the turbo was no good, all the bearings had to be replaced and redone -- basically, another full build.
All this would depend on the power goal of course, and how the car is driven.
Old Dec 13, 2009 | 09:23 PM
Joseph Davis's Avatar
Since I infer you are one of the gentlemen with money to play with, buy my T67 with the turbine exducer clipped off from shrapnel, or put me in touch with one of your friends who does. It spins freely and is basically new with ~700 miles on it. I'll make a good deal on it.
Old Dec 14, 2009 | 12:05 AM
DATSUNNY's Avatar
1998 del sol ls boosted and you just described what happened to it
Old Dec 14, 2009 | 06:45 AM
92redhatch's Avatar
What's your timing at at that boost level? 11.5-12 is usually ok
Old Dec 14, 2009 | 06:49 AM
Kelvin Racing's Avatar
Wow...
Nice build and numbers hero. Not sure how anyone can knock a 500+hp motor especially on pump.
Old Dec 14, 2009 | 07:00 AM
im at 17 degrees
Originally Posted by Kelvin Racing
Wow...
Thanks man. so far i have been more then happy with the outcome of this build. I added a larger external coil and that fixed my high rpm misfire.gonna put it on 20psi. Hope the car picks up some more power. Will find out later this week.
Old Dec 14, 2009 | 10:40 AM
92redhatch's Avatar
What are you using to tune your car? PropS on the pump gas numbers
Old Dec 14, 2009 | 11:17 AM
Thanks man. Its just on a Neptune RTP board right now.
Old Dec 14, 2009 | 07:17 PM
92redhatch's Avatar
How high are you revving?
Old Dec 14, 2009 | 07:30 PM
HamiltonRex's Avatar
get some meth injection in there and go for 650++
Old Dec 14, 2009 | 07:52 PM
Around 10k right now
Ill never use meth. Cant stand the stuff. We have a couple 100 octane pumps around. i would use that before anything else.
Old Dec 14, 2009 | 08:32 PM
92redhatch's Avatar
These numbers from a dyno jet?
Old Dec 15, 2009 | 04:08 AM
Dyno Dynamics
