ls vtec
Old Dec 17, 2009 | 07:22 PM
JdMtR's Avatar
Default ls vtec
hey im new to this whole turbo thing i currently have the ls vtec in pecies in my shop, im wondering if anyone would help me out with this, i have a eg si coupe mint, and ive been driving it for awhile now, but ive come to conclusion that its not fast enough lol, im wondering if anyone could give me a list of things i will new to properly boost my civic my goal is 450 whp. i have my turbo kit greddy t3/t4 injectors fual rail exceta, just want suggestions on pistion and rods plus a full head rebuild
Old Dec 17, 2009 | 07:26 PM
Matt55's Avatar
Default Re: ls vtec
wiseco pistons are good
eagle rods are good
stage 2 cams, like skunk2 as well with the whole valvetrain.
on ur t3/t4 with a good tune shld see 450
Old Dec 17, 2009 | 07:32 PM
JdMtR's Avatar
Default Re: ls vtec
yah but i wanna build my motor to beable to stand up to a bar of pressure, i need a good compression extimate
Old Dec 17, 2009 | 07:41 PM
Matt55's Avatar
Default Re: ls vtec
You want to know what comp wld be good for you? or do you know what comp you want to acheive already?
Old Dec 17, 2009 | 07:42 PM
Matt55's Avatar
Default Re: ls vtec
and i dont understand your post abt pressure, at sea level theres is over 1 bar of pressure
Old Dec 17, 2009 | 08:45 PM
mayfly's Avatar
Default Re: ls vtec
i see alot of people run LS turbo, but not many with LS-V. is vtec even worth it? are there power gains? or is it less beneficial than non vtec? this of course is all with turbo set ups. opinions? sorry for thread jackin. didnt wanna flood the forum
Old Dec 18, 2009 | 05:58 AM
Matt55's Avatar
Default Re: ls vtec
no its pointless to build an ls-v and then turbo it, you might as well leave it as an ls for more reliability
Old Dec 18, 2009 | 07:05 AM
pettyboy69's Avatar
Default Re: ls vtec
your kidding right? LS-vtec will make a ton more power the vtec head flows a stupid amount more than a non vtec ls head. On 12lbs my ls vtec would have walked my ls on 18lbs with the same exact turbo setup. Im not against LS motors at all, actually i like them a lot tons of tourqe ftw but with ls vtec you get that and upper rpm power because ls motors dont like to make upper end power they are a mid range motor.
As long as you do forged internals and a good tune the car should make power and be reliable as a DD
Here is one of my current setups and goals to give you an idea
91 civic si stock chassis
LS-vtec engine B16 trans
LS bottom end stock bore
SRP pistons 9:1 cr
Eagle rods
B16 head 3 angle valve job
Skunk2 valve springs and ret's
Skunk2 Tuner 2 camshafts
Turbonetics 57 trim turbo
Blox cast iron turbo manifold
RC 1000cc injectors
Im shooting for the 350-400whp range im worried bout the turbo not being big enough and also i need to upgrade my clutch but other than that the setup will make the power without any issues.
And remember your head/cams make all your power, your bottom end is just a container that needs to hold together and withstand the power
good luck with your goals
Old Dec 18, 2009 | 11:19 AM
Matt55's Avatar
Default Re: ls vtec
SRP pistons 9:1 cr
Eagle rods
RC 1000cc injectors
a fully built ls verses a fully built ls-v isnt going to be much of a difference
Old Dec 18, 2009 | 11:24 AM
hybrdthry911's Avatar
Default Re: ls vtec
you really have no idea what you are talking about so i would stop now before you make a fool of yourself.
Old Dec 18, 2009 | 01:12 PM
Turbo_TONY's Avatar
Default Re: ls vtec
please stop
Old Dec 18, 2009 | 01:47 PM
JdMtR's Avatar
Default Re: ls vtec
im thinking a smaller turbo to dull the effect of low end leg, im not making this car for a dd, its gunna be a track car complettly gutted
Old Dec 18, 2009 | 02:27 PM
Matt55's Avatar
Default Re: ls vtec
lol ok
Old Dec 19, 2009 | 02:47 AM
EFPhilly's Avatar
Default Re: ls vtec
Im going ls turbo, but my eventual power goals are going to be met with the help of ls-v. A stock vtec head verse a stock ls head....there is no comparison. B16 heads i think are the ****. I went with cp pistons, eagle rods. I havent built my head so really not much research into that. I like the cp's! I havent heard anything bad about wiseco though, lots of ppl run them. Dont go too low of compression though, because you will go through turbos faster. If you are worried about spool time, go with about a 10 comprresssion. (sorry for the typing errors...ive drank too much tonight)
Old Dec 19, 2009 | 12:09 PM
Turbo_TONY's Avatar
Default Re: ls vtec
Why would low compression pistons make you "go through" turbos?
Old Dec 19, 2009 | 02:31 PM
Rooftop voter's Avatar
Default Re: ls vtec
LS/Vtec is very benificial. It's easier to make power with a better flowing head, end point. My LS/Vtec turbo has been 100% reliable so far driving it everyday at 400whp. I don't beat on it all the time though, but it's seen it's fair share of WOT to redline through the gears. built head/bottom end.
JDMCardoso
May 17, 2010 07:24 AM
1lsvtecturbo1
Feb 22, 2009 10:55 AM
Deity
Jun 2, 2008 09:22 PM
GEN2TEG
Oct 31, 2002 12:44 PM
introspeed2
Jul 15, 2002 08:46 PM
