Injectors Questions?
Old Aug 9, 2001 | 09:35 PM
redline's Avatar
Default Injectors Questions?
I got my 310cc injectors today and measured ohms and the stocks read 12.5 but the RC read 16.5 I just looked on RCs web page and they list the range at 12-16??? Is this going to work??
also i have a 96 GSR so i got the adapter clips for my car and the wires on the clip are both black! Does it matter what wire i hook them to on the factory harness??? In threoy the injector is just a resistor that open when the voltage is applies and should not matter which way it goes through as long as the cloes/opens???
I think that i am going to plug the injectors in the hook the wires up so the some pole has the same wire as stock what do you think?
k
Old Aug 10, 2001 | 06:15 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Injectors Questions? (redline)
Im not to sure about the resistance(ohms) but I dont think .5ohms will make that much of a difference
As for the clips, the wires do not have a polarity which means they are not positive or negative. You can solder them either way.
art
Old Aug 10, 2001 | 09:08 AM
TurboInteg95's Avatar
that will work fine. I have the same injectors in my car.
Old Aug 10, 2001 | 09:31 AM
redline's Avatar
Default Re: Injectors Questions? (TurboInteg95)
well then they go in tonite with the 8:1 and i go hunting mudstangs!!
k
Old Aug 10, 2001 | 10:01 AM
that should be about perfect. I run the 8:1 as well and it's working great. Plus you've got your Fields to fine tune it a little bit.
Old Aug 12, 2001 | 02:56 PM
speedworks's Avatar
injectors will work and the wire colors do not matter
Old Aug 12, 2001 | 02:58 PM
redline's Avatar
yeah i am running a bit rich and my cat wont boost past 7psi hmmmm
Old Aug 12, 2001 | 07:20 PM
SIK IN DA HED's Avatar
New User
HOLLOW IT OUT!
Old Aug 12, 2001 | 09:27 PM
redline's Avatar
Default Re: Injectors Questions? (dlplayboy)
car not cat sorry no cat here just a big flex section
JDM C.A.R
13
May 10, 2010 07:30 AM
turbo_ef9
Jan 24, 2005 09:47 AM
schwett
Dec 30, 2003 01:38 PM
xmd
Sep 27, 2003 12:56 PM
satan_srv
Nov 15, 2002 06:12 AM
