welding manifold....
Old Aug 15, 2001 | 02:32 PM
paulzy's Avatar
Default welding manifold....
Hey guys, I need to weld a base flange for the wastegate outlet pipe. The manifold is a stainless steel. What I wanna know is, can I just weld it with any type of material or do I HAVE TO use stainless steel to weld it?
Old Aug 15, 2001 | 04:17 PM
Dee's Avatar
Dee
Default Re: welding manifold.... (Slow_ass_4dr)
Get it MIG or TIG welded. ARC welding requires a special rod to weld stainless to other steels and you have to be a good welder to get it right.
Old Aug 15, 2001 | 05:59 PM
GSRoadRage's Avatar
If the flange is just regular steel and the pipe is stainless you should weld them togeather with stainless rod useing TIG welding. If the flange is cast iron and the pipe is stainless then you can try useing stainless rod, but nickle rod may work better. And you can weld it useing TIG or ARC. The problem is the heating and cooling rate of the two metals, and that stainless tends to pull as it cools. I recommend after welding you have them wrap the two in a ceramic blanket or tin foil and let it cool down as slow and evenly as possible to avoid cracking. Good Luck!
hootiehoo
Welding / Fabrication
Sep 8, 2010 06:15 AM
90Rexx
May 18, 2010 09:56 PM
Hotori Hanso
Apr 26, 2008 04:38 PM
AH1078
Feb 10, 2007 01:35 PM
ineedhelp
Aug 1, 2005 05:50 AM
