Cracked manifold...Help!
Old Aug 14, 2001 | 10:42 AM
TurboTypeR98's Avatar
New User
Default Cracked manifold...Help!
I found a crack between the #2 and #3 cylinders on my exhuast manifold and wanted to know if this is fixable? If so, where would I take it? Welding shop, perfomance shop? Does anyone recommend a shop?
Also, are there any dangers in driving the car with the crack? The crack looks to be 2-3 inches long.
FYI - I have a Rev Hard kit.
Thanks
Old Aug 14, 2001 | 11:06 AM
Ri5e's Avatar
Default Re: Cracked manifold...Help! (TurboTypeR98)
How long have you had that manifold for?
Your best bet is to just buy a new manifold. because it'll most likely re-crack if you get it welded.
Old Aug 14, 2001 | 11:42 AM
New User
Default Re: Cracked manifold...Help! (BG Boost)
The kit has been on the car for over 2 yrs.
Anyone selling a rev hard manifold?
Old Aug 14, 2001 | 06:20 PM
GSRoadRage's Avatar
You can get it rewelded, I have welded a few of them. You have to grind out the crack and then weld it useing a nickle based rod so it will bond with the cast iron. Or another cheaper way to grind it out and braze it shut with brass, but I don't think it will hold up as well.
Old Aug 15, 2001 | 09:15 AM
ndmracing's Avatar
New User
Default Re: Cracked manifold...Help! (GSRoadRage)
You can buy aluminum weld and a blow torch at the hardware store and fix it yourself.
Old Aug 15, 2001 | 09:33 AM
turbopanda's Avatar
Default Re: Cracked manifold...Help! (ndmracing)
just weld it up dude.. it should hold up as long as you get it done somewhere that can do a proper job.. it *will* crack again sometime in the future.. but I think this would be a cheaper alternative to buying a new manifold.. keep in mind that you can't weld up the cracks forever so sooner or later you will have to get the manifold changed
Old Aug 15, 2001 | 09:42 AM
TurboInteg95's Avatar
I dont think aluminum weld will work on the cast iron manifold. My friend usually uses stainless rod to weld cast iron because of it's high nickel content.
Old Aug 15, 2001 | 10:37 AM
New User
Default Re: Cracked manifold...Help! (TurboInteg95)
Thanks for the replies guys.
I'll probably just get it welded.
Ben Huynh
Jun 19, 2007 02:00 PM
20vmini
Welding / Fabrication
Jan 2, 2005 12:19 PM
gtcali
Aug 23, 2004 03:35 PM
ludelvr
Dec 24, 2002 01:37 PM
Thats-so-Ls
Dec 7, 2002 09:23 AM
