84mm pistons
Old Aug 7, 2001 | 02:28 AM
Dee's Avatar
Dee
Default 84mm pistons
who has them onhand and has the best price? I'm gonna send my block to golden eagle next month so I might as well get bigger slugs!
Old Aug 7, 2001 | 09:35 AM
TurboInteg95's Avatar
Default Re: 84mm pistons (drealgsr)
Only place I know of that has them on hand I believe is Endyn but from all the stories on here about them it might be best to custom order them from JE. BTW, can anyone confirm if Endyn pistons are manufactured by Wiseco?
Old Aug 7, 2001 | 09:42 AM
VaporTrail's Avatar
New User
Default Re: 84mm pistons (TurboInteg95)
I can confirm that they are made by Wiseco. I know Brian Nutter from Wiseco, he'll tell you the same. I've ordered two sets of pistons and a fuel pump from Endyn within the last 3 months. I have gotten nothing but OUTSTANDING customer service from them.
Old Aug 7, 2001 | 10:00 AM
HX_Guy's Avatar
Default Re: 84mm pistons (VaporTrail)
JE has them in stock - but you have to order the B20VTEC ones unless you gte custom made. The compression will be off unless you have a B16A head.
As for Endyn, llok on their site (www.theoldone.com) under Contact Us and call one of their distributors...they should have them in stock (in 84.5mm) and can get them to you in a few days if needed.
Old Aug 7, 2001 | 10:26 AM
stizzit's Avatar
True that vapor ... The box they come in actually says WISECO, endyn machines the valve reliefs and finishes the pistons tops - I wouldn't have bought anything else.
Not to mention they have been very curtious (sp?) over the phone - the board is another story however I spoke with rick.
Old Aug 7, 2001 | 11:13 AM
Hybrid 93si's Avatar
New User
Default Re: 84mm pistons (stizzit)
I just finished building a b18c1 with RS Motorsworks oversized sleeves and Endyn 84.5mm 12:1 pistons. I used RS because Golden Eagle said the cylinder wall was cracked to far down. I do like the way GE's look better though. He is still breaking it in so no word on the power. But he didn't spend the $ to get the combustion area opened up so I'm kinda worried about detination. What do you guys think is a good redline since he rod/ stroke ratio is even worse now? Or is that really even a problem? He is also using Endyn/ Eagle rods. This was the fourth set of pistons and second set of rods from Endyn and I don't care if he is working out of his house I will buy more. The service has been great. On my first set I screwed up a ring and I called and Larry got me another set the next day.
Old Aug 7, 2001 | 11:24 AM
HX_Guy's Avatar
Default Re: 84mm pistons (Hybrid 93si)
Why do you say the rod/stroke ratio is worse now? Did he put a stroker crank in there?
Old Aug 7, 2001 | 11:40 AM
b18bturbo's Avatar
Default Re: 84mm pistons (HX_Guy)
Larry should have them in stock 84.5 mm pistons.
Old Aug 7, 2001 | 01:36 PM
Ray's Avatar
Ray
New User
Default Re: 84mm pistons (b18bturbo)
I called JE they cost 650 since they are custom
I just want 84mm(added wall thickness) and Wouldnt it be the same to order from wiseco and probably be over 100 cheaper. A local shop here sells wiseco real cheap
Old Aug 7, 2001 | 01:44 PM
New User
HX- My friend and I was thinking the same thing but Tuan over at superhonda was telling me to be careful something about rod/stroke ratio? Is there any downside to running 84mm pistons in a gsr block? Does anyone know what 84.5mm pistons in a b18c1 yield liter wise? 1.95 or so?
Old Aug 7, 2001 | 01:58 PM
HX_Guy's Avatar
The size of the pistons does not affect the rod/stroke ratio.
Rod/stroke ratio is determined by the length of the road and the stroke of the motor (crank).
I believe I saw the post by Tuan and I think he was just outlining the importance of the rod/stroke ratio - but not anything in relation to the piston size.
As far as I an see...there are no downsides to resleeving to 84mm.
Displment will be around 1970cc I believe.
Old Aug 7, 2001 | 02:28 PM
redline's Avatar
Some thing you need to consider is the added weight at 10g RPM
Old Aug 22, 2001 | 09:17 PM
Dee's Avatar
Dee
Default Re: 84mm pistons (redline)
Ummm... I'll drop Endyn an email later but are you guys talking about NA ot trubo pistons because I need a set of 84.5mm slugs that will yield a 9:1 compression ratio on a B18C.
The person who was supposed to get me a set of custom pistons flaked...
And... yes, Endyn pistons are made by Wiseco. I used Wiseco pistons when I raced Kawasaki Tecate three wheelers and 4 wheelers a very long time ago so I know Wiseco makes a good product.
[Modified by drealgsr, 10:19 PM 8/22/2001]
Old Aug 22, 2001 | 11:05 PM
VaporTrail's Avatar
New User
You're building nearly the exact same setup as I. Endyn should have them on the shelf. I believe the pistons he has on the shelf for 84.5mm should yeild you a CR of 9.0 - 9.2:1. IMHO, they are your best option, for both price and performance.
boostng r
10
Dec 19, 2006 12:50 AM
mrDFWmechanic
Mar 31, 2005 01:47 AM
tygsr
May 31, 2002 12:29 PM
