Fuel Pressure Regulator
Old Aug 14, 2001 | 10:46 PM
randomwalk101's Avatar
Default Fuel Pressure Regulator
Okay, i'm looking forward to get a Hondata stage 2 w/ boost and RC 440cc injectors through a Hondata groupbuy soon. Doug recommended that I also upgrade the stock FPR to something adjustable to tune fuel pressure....which one should I get? I have absolutely no experience in this department.
How much is the approximate cost for each of the option??
AEM fpr ?? (is this the one that totally replace the stock one?) cost???
B&M fpr ?? (is this the one that goes on top of the stock one?) cost???
Vortech ?? (goes on top of stock one..like in the "how-to" ??) cost????
which one would be the best one to pick in term of adjustability/reliablity/cost ??
Old Aug 14, 2001 | 11:26 PM
sgT's Avatar
sgT
Default Re: Fuel Pressure Regulator (randomwalk101)
i think they will all be about the same.
the b&M or vortech may be the cheapest
the aem is a 1:1 rising rate and that is something to keep in mind.
Old Aug 15, 2001 | 08:22 AM
5 Liter Eater's Avatar
Random,
I am looking into getting one so I can lower my FP enough to run the 310's. Jim (JRCivic) has the B&M for $77 shipped.
AEM replaces the whole stock FPR
B&M and Vortech are basically the same thing where you hack the top of the stock one off and clamp them on top.
The only advantage to the AEM is that it allows for lowering the FP below stock whereas the other two only really allow for increasing the FP unless you do the TOO trick where you drill a small hole in the stock FPR. For your needs I would get the B&M or Vortech as you shouldn't need to alter the FP much with the Hondata.
Old Aug 15, 2001 | 08:52 AM
dustin's Avatar
Default Re: Fuel Pressure Regulator (5 Liter Eater)
That is pretty expensive. I paid $45 for my B&M FPR.
Dustin
Old Aug 15, 2001 | 08:57 AM
GSRacer's Avatar
New User
Default Re: Fuel Pressure Regulator (dustin)
i like my aem, the b&m looks crappy to me. i also heard that it leaks air.
Old Aug 15, 2001 | 09:06 AM
TheShad0w's Avatar
Default Re: Fuel Pressure Regulator (GSRacer)
I forgot the name of the regulator I have, costs me about 80 bux, regulates up to 60 psi. Works great always makes sure I get enough fuel when needed.
Old Aug 15, 2001 | 10:19 AM
apexii's Avatar
Default Re: Fuel Pressure Regulator (TheShad0w)
I also am looking for a regulator, SX is not cheap but very nice!
Old Aug 15, 2001 | 10:24 AM
sgT's Avatar
sgT
Incorrect.
You can lower pressure below stock with all of them.
Old Aug 15, 2001 | 10:27 AM
redline's Avatar
Default Re: Fuel Pressure Regulator (sgT)
Incorrect.
Yes and no! With the big pumps that most FI people run the B&M/vortech can not get rid of enough fuel and you have a hard time lowering FP. So in theroy yes but for most of us no.
The AEM is working great for me
k
Old Aug 15, 2001 | 11:58 AM
VTEC Girl's Avatar
New User
Default Re: Fuel Pressure Regulator (redline)
If your not FI but have a header/CAI/exhaust it has been said that you can run lean at some points thru the RPM range. Is a FPR worth getting just in case.
Old Aug 15, 2001 | 12:37 PM
sgT's Avatar
sgT
Default Re: Fuel Pressure Regulator (iVTEC)
you wont run lean. but adding some fuel could make some more power.
redline's Avatar
i do not know anyone that has run lean from i/h/e. there are GSR make 185whp on the stock ECU, injectors and FPR
JacksonD
Mar 26, 2010 07:13 PM
irishflame27
Dec 9, 2008 06:14 PM
85mm LS VTEC
Mar 25, 2004 10:52 AM
Mark
Sep 15, 2003 11:00 AM
HXMan
Feb 4, 2002 12:51 PM
