CRX Compression numbers
Old Aug 7, 2001 | 11:51 PM
dustin's Avatar
Default CRX Compression numbers
I did a compression test on my newly purchased CRX w/ ZC.
Chassis has 140k on it but the engine was supposed to only have 35-40k on it.
I got between 200 and 210 psi in all cylinders when I did the compression test on the motor. Doesn't this seem high? Compression for the motor is 9.6:1
Dustin
Old Aug 8, 2001 | 12:05 AM
LsTurbo91's Avatar
Default Re: CRX Compression numbers (dustin)
sounds normal.... I did mine on my ls 195ish on all cylinders.
Old Aug 8, 2001 | 05:32 AM
MiraiZ's Avatar
it might be modded...thinner head gasket??
Old Aug 8, 2001 | 06:57 AM
Rob03Pro5's Avatar
Default Re: CRX Compression numbers (MiraiZ)
Generally if your car has unusually high compression numbers, it indicates that you have lots of carbon build-up in your motor. But having around 200psi should be about normal for the CRX.
88 civic
Apr 5, 2009 03:21 PM
self_made
Jun 19, 2005 12:36 PM
civic-crx-mix
Mar 2, 2005 02:57 PM
sdinteg
Feb 1, 2005 07:52 PM
