boost gauge problems?
Old Aug 10, 2001 | 11:31 AM
clean's Avatar
New User
Default boost gauge problems?
guys i put my boost gauge tube to my fpr and it reads vacum wtf? on the directions from autometer it says to hook it to a pressure port on the engine. where? where did everyone else hook it too?
Old Aug 10, 2001 | 11:40 AM
LsTurbo91's Avatar
Default Re: boost gauge problems? (clean)
thats what its suppose to be. your engine is always on vacuum until you reach boost.
Old Aug 10, 2001 | 11:41 AM
92CivicSiR's Avatar
New User
first of all you DO NOT hook up a boost gauge to the Fuel Pressure Regulator. Why would you do a thing like that? When it tells you to hook it up to a pressure port on the engine, it means that you need to install it in-line on one of your vacuum lines. Hope this helps.
Old Aug 10, 2001 | 11:45 AM
clean's Avatar
New User
Default Re: boost gauge problems? (92CivicSiR)
then where does it go? i was told to hook it up to my fpr by some people here on this forum and someone up here. where would a pressure port be? am i ignorant?
Old Aug 10, 2001 | 11:50 AM
sgT's Avatar
sgT
The line to the FPR recieves vacuum/pressure signals. That is where you should hook it up.
Old Aug 10, 2001 | 08:34 PM
LsTurbo91's Avatar
Default Re: boost gauge problems? (sgT)
You can tap several places on the intake manifold. The FPR is just fine.
Old Aug 12, 2001 | 07:28 AM
92CivicSiR's Avatar
New User
Default Re: boost gauge problems? (9psiLsT)
I dont know what I was thinking that day. Everybody is right, there is many places on the intake manifold to hook it up, and the FPR will work just fine. Like everybody else said, the gauge will always read vacuum until the turbo starts to provide some positive pressure. I know this is probably stupid, but I am assuming that you have a turbo. I would hope that you don't hook up a boost gauge on a NA engine. hehe just me being stupid again. Listen to what people say, hook it up to the FPR. It will always read vacuum until higher in the RPM band when the turbo winds up. I hope that you get it figured out.
Old Aug 12, 2001 | 11:10 AM
clean's Avatar
New User
yah thanks guys, i thought it would be better there. oh and the guy a honda ment for me to T it to the cruise control before the check valve, but he pointed to the vacum after the check valve. oh well
Old goat
Jan 17, 2015 05:00 PM
VyTaL
May 1, 2009 08:01 AM
ericstambaugh07
May 22, 2007 06:45 PM
Renegade
Jul 6, 2005 01:35 PM
Guitarzann
Dec 18, 2001 09:56 AM
