anyone in here use the starion/conquest intercooler?
Old Aug 5, 2001 | 08:02 AM
lucas569's Avatar
Default anyone in here use the starion/conquest intercooler?
i have a friend that had one on his civic and he had it polished and fixed the bent fins,anyhow he bought a rev-hard kit and was selling the starion ic at a good price,anyone know if this thing would be suffient for a t4/t3 turbo?
Old Aug 5, 2001 | 08:15 AM
Rob03Pro5's Avatar
Default Re: anyone in here use the starion/conquest intercooler? (lucas569)
A friend of mine has a Starion IC and another budy with an Eclipse GST also has one. They can supposedly handle around 300-330 hp.
Old Aug 5, 2001 | 10:28 AM
lucas569's Avatar
well i read in another forum a little while ago that these ic's arent that great. alot of this stuff is hearsay so i dont know...
Old Aug 5, 2001 | 11:24 AM
Rob03Pro5's Avatar
Ya, lots of it is hearsay. But if you would look at the size of the intercooler, it should be sufficient for around 300hp.. that's assuming the core is in good condition and has had a leak/pressure test. One of those guys i mentioned had his tested up to 25psi of pressure with no leaks.
Old Aug 5, 2001 | 12:58 PM
98hx99b18c's Avatar
Default Re: anyone in here use the starion/conquest intercooler? (Rob92SC)
Ya, Im running one with a T3/T4 setup, had it pressure tested...made custom endtanks and brackets for it, works fine....here's a pic...http://hometown.aol.com/khmani5150/khmani5150.html
Old Aug 5, 2001 | 08:01 PM
TurboMiata's Avatar
Default Re: anyone in here use the starion/conquest intercooler? (98hx99b18c)
This is whats on my car. FWIW, at 12psi on hot days the "after intercooler/TB" pipes are almost "room" temperature, while the before intercooler pipes are so hot you can';t touch them. this is on a Tdo4-15C (same as greddy honda kit) though, not a T3/T4. Shouldn't be much a difference unless your oosting alot higher though since the larger turbo actually would create cooler air at the same boost.
Old Aug 5, 2001 | 10:06 PM
lucas569's Avatar
Default Re: anyone in here use the starion/conquest intercooler? (TurboMiata)
thanks guys, i might just pick this ic up till i have the dough to buy a spearco...
Old Aug 5, 2001 | 11:02 PM
93LSivic's Avatar
I have one. I just need the turbo, downpipe, FMU, charge pipes, BOV, and fuel pump. Another words, I have that and my boost gauge, and thats it for my do-it-yourself turbo kit. Sure looks nice sitting here in my room though..........I will be boosting soon!!!!
integracivic94
Sep 4, 2006 10:08 AM
cxVtecC1
Dec 1, 2004 07:57 AM
Lewie
Feb 21, 2003 07:01 AM
black_sh
Feb 1, 2003 10:41 AM
