is this time good?
Old Aug 13, 2001 | 10:07 AM
synergy004's Avatar
Default is this time good?
I ran my bros car last weekend at the track. I hit consistant 14.3's back to back three times @91 MPH on slicks with 1.90034 60 FT's.
It is a 91 CRX SI with a 94 EX motor. Vtec never engaged while running. HAving VTEC problems. Clutch was slipping after first burn out. Bone stock except for a Greddy TDO4 turbo bolt on kit. No other mods were done. just wondering if this time sucked, I was just concidering that it was done on 6 psi of boost and never redlined during the runs. Shifted at 6100 RPM's. I was just thinking if the times could have been lower.
thanks if you reply.
Old Aug 13, 2001 | 10:12 AM
chri5's Avatar
Default Re: is this time good? (synergy004)
i think that's a pretty good time, especially with things not running properly. Get the VTEC to engage so you can go to redline (7000 right?) and get a slightly beefier clutch and your def in the 13s
Old Aug 13, 2001 | 11:50 AM
bgod's Avatar
Default Re: is this time good? (Strng1dah)
damn, 91mph. isn't that a bit low even with no vtec engaging on a single cam d series motor.
unless you get the vtec problems out of the way, can't see how you can much improve on that 1.9.
Old Aug 13, 2001 | 03:50 PM
synergy004's Avatar
Default Re: is this time good? (bgod)
we were thinking the same thing about the MPH. The plan is to beef up the whole motor, add ignition, race gas, better clutch and try to hit that 13 sec run.
thanks
Old Aug 13, 2001 | 04:51 PM
JohnShaft's Avatar
New User
I've been wondering what it takes to get 60' times like that. You must have been running slicks.. what size?
Good runs considering the problems you were having!
Old Aug 13, 2001 | 07:23 PM
TurboInteg95's Avatar
man, I think if my clutch was slipping I wouldnt continue racing. You might not be able to make it home.
Old Aug 14, 2001 | 09:25 AM
synergy004's Avatar
Default Re: is this time good? (TurboInteg95)
I was running the 15x8x22 Mickey Thompsons on the Kosei 5 spoke rims
I wonder what 60 ft's I will run with my Bogart 13x8.5x25's Mickey thompsons On my fully built Hatch 92. I will prolly break an axle since these look to big.
JDMEF-8Si91
61
May 9, 2005 08:48 AM
desert eagle
May 8, 2004 11:12 AM
MUGEN_B16CIVIC
Jan 13, 2004 10:18 AM
HoNdAcRx88
Jun 26, 2002 05:31 PM
5gen-hybrid
Aug 21, 2001 05:04 PM
