Boost Spiking! Need help ASAP going to DYNO TOMMOROW AAAHHHH!
Ok guys I need all of your help right now. So here is the deal. I have a Drag gen 3 kit on my Type R. Tommorrow I go in for HONDATA! Which also includes 4-5 hours of dyno tuning!
But here is the problem: I am boost creeping bad! I have a delta wastegate that came with my Drag kit. I just put the lowest psi spring (the green one). It is supposed to boost 3-5psi, but no..... mine goes up to .69bar or basically 10psi!
I have a 3" downpipe and 3" exhaust all the way back. So I expected it to be a little higher then 3-5psi but not 10!
I have the wategate plummed from the compressor, to the side of the wastegate.
I have the AVCR boost controller, however it is not hooke up at all.
This is the EXACT same kit I had on my LS integra and it NEVER boost creeped/spiked.
So any ideas on how to keep the boost from spiking? I need to know soon cuz i am going to the dyno tommorrow!
Thanks
Chris
PS- Is it possible I am just flowing to much air for the delta to handle? maybe its time for tial..
Thanks
Chris
Re: Boost Spiking! Need help ASAP going to DYNO TOMMOROW AAAHHHH! (TurboIntegra)
are your hoses new ?
i'm using a tial wastegate and i had the reverse problem of yours. I couldn't boost past the spring. So i upgraded to b igger hoses and the problem went away.
Let me know if you need a Tial wastegate. You can pick one up from our warehouse on the way to the dyno.
Re: Boost Spiking! Need help ASAP going to DYNO TOMMOROW AAAHHHH! (ben@importparts.com)
Ok, just ordered the Tial. I hope this solves my boost creep problems.
New User
Where in SD are you getting the hondata done at? what stage and how much? just wondering cuz i'm seriously considering going that route, and i'll probably be moving to SD soon! let me know! hope it works out for u
Re: Boost Spiking! Need help ASAP going to DYNO TOMMOROW AAAHHHH! (veejay)
Try one of these. We ran it up to 16psi and it held perfectly.
http://www.c-speedracing.com/howto/mbc/mbc.html
Synapse
10-05-2007 01:12 PM
