440cc injectors on a turbo h23
440cc injectors on a turbo h23 i run 8 psi now on stock injectors but i got some 440cc one in and i am going to run like 15psi and everyone tell me its going to idle idle like **** so how can i fix it with out buying a stand alone ecu right now i got a stock ecu that been chiped by hondata let me know what u think or can i just put my fuel psi very lower will that work
car is a accord with a h23 runing a t3 turbo intercooled with je pistons inline fuel pump and a rise rate regulator and stage 2 head work
Re: 440cc injectors on a turbo h23 (Purelude)
nope did have them yet but i can call them and get it re chipped right what about would a safc fix it
Re: 440cc injectors on a turbo h23 (DLB1994)
Get the afc and lean out the lo setting at 1,000 rpm. You might have to lean out like 18% or so. Anybody that tells you can't run 440'c is lying. If you got the afc you can adjust the percentages to make the injectors idle and run right.
EVIL
EVIL
yea you can use the afc to run around town. fuel at wot is questionable, get it on a dyno. if you want to push more than 7psi why not buy the hondata stage 2 system so that it can accurately read boost.
if i go to a stage 2 i got two get a teg Ls ecu and then get that one programed
any thing over a stage 1 u got to have a b18 or b16 and d16 ecu f22 or h22 or h23 ecu they cant do
