turbo for stock b20z engine
Old Aug 11, 2001 | 04:34 PM
dohc_Cx's Avatar
New User
Default turbo for stock b20z engine
ok maybe this forum can help..just wanna know if this motor is good for turbo like the ls engine is..being this motor doesn't have that high of compression ratio..thanks
Old Aug 11, 2001 | 10:16 PM
dohc_Cx's Avatar
New User
Default Re: turbo for stock b20z engine (rACEr_b_O_y_)
anyone know anything on this tpic
Old Aug 11, 2001 | 10:47 PM
Ray's Avatar
Ray
New User
B20z: CR 9.6:1 84mm Bore LS Crank/rods
B20b: CR 8.8:1 84mm Bore LS Crank/rods
B18a/b: CR 9.2:1 81mm
B20head is the same as a B18b head except for the intake manifold and 84mm head gasket
Boosting a B20 would be very much like a B18a/b except for the increased torque.
B20 sleeves are stronger also(siamese)
Old Aug 12, 2001 | 09:52 AM
dohc_Cx's Avatar
New User
Default Re: turbo for stock b20z engine (Ray)
thanks..one more question..do you think this motor can take 10 psi of boost or more?
Old Aug 12, 2001 | 10:28 AM
lucas569's Avatar
i thought the rod to stroke ratio wasnt ideal on the b20? theres a site dedicated to the b20 check that out for loads of info. i think its http://www.b20.com
Old Aug 12, 2001 | 06:21 PM
dohc_Cx's Avatar
New User
Default Re: turbo for stock b20z engine (lucas569)
i can't get into this site..any more help..very much appreciated..thanks
Old Aug 12, 2001 | 06:57 PM
Ray's Avatar
Ray
New User
With the right timing and fuel, yes
endyn says the block can handle 14psi
apekd
Sep 2, 2008 04:08 PM
hondaj05
Apr 13, 2006 08:06 PM
electric_rex
Oct 13, 2004 05:16 PM
viCeVerSa
Dec 19, 2002 11:14 AM
BoostedD15B7
Sep 24, 2002 03:06 PM
