Turbo grief.....
Old Aug 8, 2001 | 05:19 PM
Blown90hatcH's Avatar
Default Turbo grief.....
Modified by Blown90hatcH at 8:49 PM 6/8/2006
Old Aug 8, 2001 | 08:44 PM
TurboInteg95's Avatar
Default Re: Turbo grief..... (Blown90hatcH)
your fuel pressure should be somewhere around 140 with those stock injectors. That isnt possible so either back off the boost to about 7 psi and get a Bosch pump or upgrade your fuel pump to a Bosch and get 310's and an 8:1 disk and keep the boost at 10. Either way you need a fuel pump but if you want to keep running high boost you need to get larger injectors.
Old Aug 8, 2001 | 08:46 PM
JSpecwest's Avatar
New User
I had the same exact problem in my R. I have no clue...you may need a gasket on your wastegate so it seals properly, or it could be a fuel problem. If you figure it out, let me know.
Old Aug 9, 2001 | 02:31 AM
MiraiZ's Avatar
Try lower boost...7psi...sound as if youre leaning out
VTECth1s
Apr 22, 2006 09:42 AM
AZNracerx1989
Sep 23, 2005 11:28 AM
switchblade
Apr 24, 2004 02:07 PM
zcivic91
Aug 15, 2002 05:38 AM
smoothludey2
Oct 1, 2001 03:27 PM
