1\4 mile times with turbo
When I go turbo (DRAG or F-MAX) with my 92 LS, what kind of 1\4 mile times will I expect at the base 7 or 8 psi (I think) the kits come with?
Re: 1\4 mile times with turbo (bgod)
Currently running a 16.2... drag kit with 7psi will net you a low 14 on street tires. Do not listen to anyone above ok ?
Dustin
Dustin
New User
yah i agree with bgod. you should get mid to high 13's with 7 psi. with 6psi ive gotten mid 14's and thats with street tires and full interior.
I'm confident I can get that 16.2 down some more. Probably 15.9....The weather the day that I ran was in the 90's and it was muggy as hell + My front tires need to be replaced soon. Anyway, more responses please....
Re: 1\4 mile times with turbo (Strng1dah)
let's assume I get low 14's on street tires. How much psi would I have to be running to get to mid-to-low 13's. And at what psi will the stock bottom-end be vulnerable.
Re: 1\4 mile times with turbo (sando112)
what should i expect running my turbo. t3/to4e at 7 psi with intercooler.
I currently have a best time of 15.1 @91 with my Si(R) with I/E only!
Re: 1\4 mile times with turbo (SiRkid)
The 90-93 integras are lighter then the 94+s. I believe 2300 lbs? This guy ran a 11.9 @ 14 psi on slicks with a full built engine with full interior except for a spare tire. So 7/8 PSI should net you high 13's, low 14's on street tires. but hey...it all depends on the driver and the traction.
My(2 teg weighs in at 2470... with everything in except the spare tire. That is with a 1/4 tank of gas. My car ran 15.3 with the LS motor... I cannot seem to remember the trap speed right now I think it was arount 89-90. I swapped in a B16and ran it again i ran a 15.3 again with 93 mph with a high 2.4 '60 ft time. I was running on borrowed 14 inch wheels with all season tires.
Now I am running a a turbo on the car with T3 running 5 psi... that car seems like a low 14 car... I have not run as yet but my friend has a mid 13 sec miata.. comparing my car to his that is what it seems like. I could be wrong though
Hassan
Hassan
New User
juts installed a revhard kit for a friend on his 95 LS @ 7psi on the AEBS dyno it made 220hp and 185 TQ and ran 13.6 @ 104 w/ 2.0 60 ft on 14"nittos drag radials
New User
Re: 1\4 mile times with turbo (dustin)
Dustin
Dustin
Prior to my turbo I ran a best e.t. of 15.5 w/ a stock B18c1 motor in a 95 civic coupe on street tires and I am a very good driver.
Re: 1\4 mile times with turbo (dragonsmp)
So how much boost should I be running to hit mid to high 13's then? And do I have to reinforce my stock block?
i think the revhards kits is good up to 9psi before reinforcement of bottom end is needed. i dunno bout wat the other guy said that it will net u a low 14?! more like net u 13's...all day....12's w/slicks. if a 50shot nos is gonna get u to the 14's.....wat do u guyz think a t3/t4 hybrid is gonna do for u?? MUCH more pull. just how i thought it was supposed to be
South Bay Surfer
13
07-02-2008 07:53 AM
