how to check if my skunk2 gears are whack?
how to check if my skunk2 gears are whack - timing ?
Is there any way to tell if the skunk 2 gears that i have are off? they are set at 0,0 and i was thinking that they might be off.
[Modified by Purelude, 11:37 AM 8/10/2001]
Re: how to check if my skunk2 gears are whack - timing ? (Purelude)
yea... degree them. You'll need a degree wheel, some coat hanger, a dial indicator - all can be found from JEGS then you'll need to learn how to do it. Books on engine building can be found at barnes and noble and other online stores (amazon.com). Good luck
Re: how to check if my skunk2 gears are whack - timing ? (stizzit)
i use to own skunk 2 gears. i thought they sucked *****. the quality was horrible so i wound up selling them. the only ones i've seen that i would trust is str.
