MAP Sensor
Old Aug 15, 2001 | 03:13 PM
Turbo EG6's Avatar
New User
Default MAP Sensor
Finally getting my car running right, but everytime I make a pass down the street and come back the car stumples and throws the map sensor code. I unplug the ecu and plug it back in and its gone. I am seeing 10psi in every gear, and I am running a missing link. Any ideas? Also what do I need to run a 2 or 3 bar map sensor?
Old Aug 15, 2001 | 03:14 PM
sgT's Avatar
sgT
Default Re: MAP Sensor (Turbo EG6)
you need an ecu that is capable of reading the signal from a 3 bar map sensor.
FYI, hondas come with 2 bar map sensors.
Old Aug 15, 2001 | 08:30 PM
Turbo EG6's Avatar
New User
Default Re: MAP Sensor (sgT)
Anyone have any ideas why its throughing the map sensor code?
Old Aug 15, 2001 | 08:32 PM
Blown90hatcH's Avatar
We are running with RC 440's and a VAFC. When we dump extra fuel into it....it throws the MAP sensor code......Someone has to have had this problem.....What can a stock honda map take with the missing link?
Jason
Old Aug 15, 2001 | 09:32 PM
Ray's Avatar
Ray
New User
Default Re: MAP Sensor (Blown90hatcH)
you have a missing link and the map sensor still throws a code? sounds like the missing link isnt working, might be clogged
Old Aug 16, 2001 | 01:08 PM
liam821's Avatar
25 Year Member
Default Re: MAP Sensor (Ray)
thats my guess too...something is wrong with the missing link. If you have a apex SAFC you can see what the MAP sensor is reading...i bet its seeing boost..
liam
Old Aug 16, 2001 | 01:49 PM
redline's Avatar
Default Re: MAP Sensor (liam821)
or you are trying to add to much fuel via the afc and it is throwing a code
Old Aug 16, 2001 | 01:52 PM
Ray's Avatar
Ray
New User
Default Re: MAP Sensor (redline)
buy a few check valves and see if the cel still comes on. If the cel still comes on then your map sensor is bad or it's something else.
Old Aug 16, 2001 | 03:27 PM
dbman96's Avatar
New User
Apparently someone doesn't understand how the VAFC works. The way it adds fuel is by increasing the voltage the ECU sees from the map sensor. The Missing Link only ensures that the voltage coming from the map sensor is no greater than the signal for atmospheric pressure. So if you modify that with the VAFC, if you increase it more than a few percent, then at WOT or under boost the ECU will see greater than atmospheric pressure signal from the MAP sensor and throw a code. This is why if you're tuning with a VAFC you really need to design your fuel system to be rich in all conditions and then use the VAFC to lean it out from there. Kick up your fuel pressure a bit and lean out the VAFC.
Incidentally, as bad as the VAFC manual is, it does explain this whole issue.
And might I add that with a Rev-hard kit at stock boost and 440s there's no reason in the world you should have to add fuel with the VAFC.
[Modified by dbman96, 4:28 PM 8/16/2001]
Old Aug 16, 2001 | 07:41 PM
Ray's Avatar
Ray
New User
Default Re: MAP Sensor (dbman96)
I see, never looked into a afc.
Old Aug 17, 2001 | 07:22 AM
dbman96.....we are running about 10-11 psi.
Old Aug 19, 2001 | 05:04 PM
speedworks's Avatar
missing link can not be working correctly. one way aquarium valves can be used
to bleed off boost to map sensor. cheap and works great. use one for every 5
pounds of boost
dominate9
Nov 15, 2003 01:01 PM
CiViC SiR
Jul 7, 2003 02:55 PM
forced-d16
Sep 22, 2002 11:46 PM
