Asking the pro's?
Old Aug 9, 2001 | 02:26 PM
BlwnBlue's Avatar
Default Asking the pro's?
I've heard alot of people that say they use stock rings? Instead of total seal, How is this possible? I mean the rings are usually the first thing to go on a turbo motor aren't they?
Reason I am asking is cuz I have a fully built b16 w/ benson sleeves,arias pistons 9:1, total seal rings and crower rods w/ a micropolished crank...
The motor isn't in the car because I am waiting to purchase a stand alone.. hence my other post..
but my question is while I have the motor out should I change the rings now? or go ahead and use the rings that are in there?
Old Aug 9, 2001 | 02:29 PM
dustin's Avatar
Default Re: Asking the pro's? (BlwnBlue)
Might as well use them... if they leak you can always replace them with stock.
Dustin
Old Aug 9, 2001 | 11:34 PM
VaporTrail's Avatar
New User
On a stock bottom end, the ring lands are the first to go. This is a part of the piston, not the rings themselves.
I've personally built several f/i motors using stock rings. They don't seat as fast, but once they do, they are plenty durable and seal adequately. If you're not worried about longevity, Federal Mogul rings seat very quickly, seal pretty well, but don't last too long. My experience with Total Seals were that they did not seat fast, and they are a bitch to seat at all. Anyway, hope that helps
Old Aug 10, 2001 | 12:02 AM
Ray's Avatar
Ray
New User
Default Re: Asking the pro's? (VaporTrail)
so seated stock piston rings will last the longest even at 350whp?
Old Aug 10, 2001 | 12:10 AM
VaporTrail's Avatar
New User
Default Re: Asking the pro's? (Ray)
In my experience, if they are properly taken care of (little to no detonation), yes they will last the longest.
Old Aug 10, 2001 | 12:18 AM
Ray's Avatar
Ray
New User
probably stick with aftermarket.
Old Aug 10, 2001 | 06:03 AM
BlwnBlue's Avatar
"My experience with Total Seals were that they did not seat fast, and they are a bitch to seat at all"
What do you mean by seat?
You're meaning the break in period of the motor right, it has to be driven around longer to allow them to seat,right?
Old Aug 10, 2001 | 06:26 AM
Big James's Avatar
New User
VaproTrail, let me ask you a question then. What would do when you use JE Pistons, since the grooves for the ring are too small for stock rings? have you had any experience or luck with making them larger to use a stock ring on a JE Piston?
Old Aug 12, 2001 | 03:06 PM
speedworks's Avatar
remove the (no seal)total seal rings while the motor is out.these rings are junk.
i have already been through this.i put arias in my car and they seated instantly
factorys work great,and je's are good to.heed my warning!
Old Aug 13, 2001 | 05:55 AM
BlwnBlue's Avatar
Default Re: Asking the pro's? (speedworks)
I did not know that arias made rings...
I appreciate it..looks like I'll take em out..think I'll go w/ arias since that is the piston setup being used..
boost fed ls
Nov 14, 2004 09:15 PM
SIK IN DA HED
May 16, 2003 09:50 AM
turboteg96
Feb 11, 2003 06:48 PM
mracura
Jun 4, 2002 07:46 PM
rioninja
Jul 31, 2001 05:37 PM
