can I run greddy turbo with Zex nos kit?
Re: can I run greddy turbo with Zex nos kit? (puffy)
yes you can if you got the fuel and everything is correctly tuned. I would use a better nos kit though. I am not fond of the ZEX kit in turbo application. I would use a nos 5122 kit with progressive noscontroller with remote bottle opener and purge kit.
Re: can I run greddy turbo with Zex nos kit? (b18bturbo)
is that a wet or dry system??? isn't it good to have nos w/turbo cause nitrous will cool down the boost. at least that's what i heard.
yes u can. use about a 30 shot jet if you have stock bottom end. you will need to
lower boost level because it will increase your boost when you engage nitrous.
turbo will spool up instantly(bye bye turbo lag) hello smoking tires
