help with jrsc
Old Aug 16, 2001 | 07:09 PM
alltech's Avatar
Default help with jrsc
I have a 93 si and was getting ready to install jrsc. What all needs to be upgraded for safe install at 6 psi. The motor was just rebuilt new bearings, rings,seals,and belts. Also as anyone used the new jrs maping sys. they have out ?
Old Aug 16, 2001 | 07:37 PM
falcongsr's Avatar
What is this crap?
Default Re: help with jrsc (alltech)
upgrade the fuel pump and get the MAP convertor. you will be good to go. The MAP convertor is the **** and it might be included in the kits soon.
Old Aug 16, 2001 | 08:57 PM
alltech's Avatar
Default Re: help with jrsc (falconGSR)
what fuel pump would you go with, and an in tank or piggy back set up.
Old Aug 17, 2001 | 07:15 AM
Racing rice's Avatar
New User
Id go with the In-tank.. It might not be a bad Idea to run a FPR and get some gauges to help you tune it so you dont blow your motor... Remember... Good tuning is your best defence against detenation..
Old Aug 17, 2001 | 08:36 AM
Muad'Dib's Avatar
Corr Performance Pilot
High Pressure Fuel Pump (intank)
Fuel Gauge and boost gauge
FPR
J&S (optional but recommended)
a/f meter
That should be it for 6 psi.
If you have more questions drop me a line.
Old Aug 18, 2001 | 07:32 PM
alltech's Avatar
Default Re: help with jrsc (MouhadIb)
what about timing stock or retard and what type plugs? Also would you drop to a 160 thermostate?
oacrep1
Feb 6, 2006 07:34 AM
STREETWERKZ
Dec 24, 2005 11:19 PM
hondaeg8
Jun 17, 2005 01:28 PM
DeDonDeRosa
Dec 16, 2002 11:19 AM
grand600
Sep 27, 2001 09:58 PM
