what's the difference between electrical and mechanical boost gauge ?
Old Aug 7, 2001 | 07:11 PM
Flamenco-T's Avatar
Default what's the difference between electrical and mechanical boost gauge ?
how do they work differently ?
and which would you recommend ? is it the same myth as electrical is easy to install, but too accurate, versus, mechanical is a little harder to install but very accurate ...
[Modified by flamenco, 8:13 PM 8/7/2001]
Old Aug 7, 2001 | 07:25 PM
TurboInteg95's Avatar
Default Re: what's the difference between electrical and mechanical boost gauge ? (flamenco)
electrical boost gauges have a sending unit that turns boost into an electrical signal that it sends to the display. they are more accurate. With the mechanical gauge you have to run tubing to the gauge and they tend to be not as accurate.
Old Aug 7, 2001 | 07:31 PM
Flamenco-T's Avatar
Default Re: what's the difference between electrical and mechanical boost gauge ? (TurboInteg95)
great, I just purchased one...
thanks
Old Aug 7, 2001 | 07:49 PM
falcongsr's Avatar
What is this crap?
I saw arturbo's Greddy boost gauge...it looks like a GM MAP Sensor is the 'sending unit'. I could be wrong about it being GM it was dark...
Joe
skuded
Apr 21, 2011 04:38 PM
driveahonda
Feb 23, 2007 12:59 PM
hondaaccord94
Aug 9, 2006 05:19 PM
T3T495GSR
Aug 20, 2003 04:23 PM
