Strange EGT readings
Old Aug 8, 2001 | 02:38 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Strange EGT readings
Ever since I put on the 3" exhaust Ive noticed that my EGT have been cooler. I took a road trip on Monday and I noticed when I was crusing around 100mph my EGT was 700deg Celcius. So that seemed kinda ok, but then I wanted to see what it would be at 75mph where is usually reads 700deg celcius aswell. But it read 600deg.
Also, when Im done driving after about a 25miles then Im about to let idle for the cool down, the egt just drops faster than normal. I sure it has to do with the exhaust larger volume and the turbo is doing the same amount of work.
what do you guys think?
art
Old Aug 8, 2001 | 03:15 PM
GSRwBOOST's Avatar
Default Re: Strange EGT readings (Arturbo)
i think less back pressure allows the engine to breath easier and allows it to cool quicker...
my egt probe is down on the downpipe near where the cat would be and it reads about 50degress cooler than dustins at 80mph constant speed... ?
Old Aug 8, 2001 | 03:17 PM
outlawtas's Avatar
New User
Default Re: Strange EGT readings (GSRwBOOST)
isn't as cool as possible better?
Old Aug 8, 2001 | 04:13 PM
rtype11's Avatar
same happened with me, this is normal, just ue the new figure as your baseline for watching egt
Old Aug 20, 2001 | 10:59 PM
DIRep972's Avatar
Smarter than you
Default Re: Strange EGT readings (rtype11)
ive been reading corky bells book maximum boost and he says that back pressure causes your motor to run hotter so this is proabably a good thing art.
Old Aug 21, 2001 | 08:33 AM
ssblue's Avatar
Default Re: Strange EGT readings (DIRep972)
even though your horsepower will increase with the larger 3"inch downpipe and exhaust, will it actually be safer for your engine since the egt's are lower?
ozzyman
Nov 13, 2005 12:59 PM
xrtdac
Dec 20, 2003 11:17 AM
11secdx
May 21, 2003 08:41 AM
gigantor
Aug 28, 2002 03:37 AM
BluLuder
Nov 6, 2001 05:33 PM
