300 whp /w JRSC
Old Aug 16, 2001 | 10:56 AM
pstreck's Avatar
New User
Default 300 whp /w JRSC
Is it possible to get 300 whp out of the JRSC?
Old Aug 16, 2001 | 10:57 AM
pstreck's Avatar
New User
Default Re: 300 whp /w JRSC (pstreck)
ack, on a b18C1
Old Aug 16, 2001 | 11:27 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 300 whp /w JRSC (puffy)
Not untill the intercooler is made. If it works, which I hope it does work out for the SC guys. 12psi non intercooled is not good.
art
Old Aug 16, 2001 | 11:30 AM
jinxproof99's Avatar
New User
if your motor was built, you had a 11lb pulley, had they correct fuel management/tuning, and sprayed a 50 shot, you would be close to that figure......but why would you want to? it would be risky and probably not cost effective......especially if your just "trying to be different"
Old Aug 16, 2001 | 11:51 AM
VaporTrail's Avatar
New User
Default Re: 300 whp /w JRSC (jinxproof99)
GSR +12psi + intake + quality header + no exhaust/cat + 25shot wet + clutch = 320hp/260tq. Stock everything else. Been there, done that, ran a 11.2@123mph in a Civic on slicks with that.
But, if you want it reliable, I'd highly recommend pistons, rods, and a management system like Hondata.
Old Aug 16, 2001 | 02:31 PM
iceman's Avatar
That much boost on a M62 would be problematic without an intercooler of some kind (NOS).
Old Aug 20, 2001 | 09:23 PM
DIRep972's Avatar
Smarter than you
Default Re: (iceman)
i was thinking about it once and if i had a JRSC i would do the ENDYN upgrade for 9lbs of boost, of course the JRSC intercooler when it comes out, header w/ a 2.5" collector, high flow cat, and apex N1 exhaust.. and CAI... that set up could be around 275hp i think if the intercooler works out nice..
Old Aug 20, 2001 | 10:18 PM
SpoonCivic's Avatar
New User
Default Re: (DIRep972)
some dude in toronto is running an ITR with JRSC, built bottom, 100shot, and is running like 350whp
Old Aug 21, 2001 | 05:47 AM
TypeC's Avatar
Default Re: (SpoonCivic)
but what happens when you run out of Nitrous (it's not like you spray everytime at WOT)? That's a draw back of pully driven boost. I say DRAG baby, DRAG!
Old Aug 21, 2001 | 07:08 AM
lundgren's Avatar
Your HP may not be that high, but you can generate a huge amount of torque accross a wider range than most turbo kits making 300 whp that's for sure. For a drag race car that wouldn't do, but for the street, a broad range torque band is much more usuable, that a car making only 300 whp, unless of course you drive your car from 7-8k all the time.
Old Aug 21, 2001 | 10:24 AM
H23 Power's Avatar
Default Re: 300 whp /w JRSC (TypeRgirly)
autocrossing/road racing...torque is god
well, for honda/acura's it is...too much is bad...but if you have good tires, its hard to have too much torque
[Modified by 01GSR, 1:25 PM 8/21/2001]
Old Aug 21, 2001 | 02:20 PM
lundgren's Avatar
I'd rather have 150 ft-lbs of torque at the wheels from 3-7k than 120 from 3-5, and 170 from 5-7k. Even if the later makes more HP, the torque in the previous is better used for a daily driver and autox, and really that large surge is what creates traction problems.
hondaapi
Jul 12, 2006 03:50 AM
jxj220z28
Aug 23, 2005 04:35 PM
2K Teggy
Oct 16, 2003 06:26 PM
siis2fast
Jun 25, 2003 09:22 AM
Dustin98lude
Jun 1, 2003 07:00 PM
