physical mod to fit DSM injectors...
Re: physical mod to fit DSM injectors... (Slow_ass_4dr)
the dsm injectors i have the std plugs on them. My rc plugs work fine.
If you mean manifold/rail fitment, mine go in fine there as well.
New User
Re: physical mod to fit DSM injectors... (Inlinefour)
All of them fit; just make sure you get the ones off a 5-speed turbo model; the automatics are only 350s instead of 450s. On my car it worked better on the injector/manifold seal to use the rubber seats that came with my RC injectors than the OEM ones; the RC seats are taller so they hold the DSM injectors a little better. I think the DSM injectors are almost IDENTICAL in size/shape to the RC injectors so I consider them to fit as good or better than the RCs. Where they plug into the fuel rail I suggest swapping the OEM o-rings in place of the DSM ones as well. The Honda o-rings are a bit thicker and look like they seal better.
Re: physical mod to fit DSM injectors... (dbman96)
I just wanted to let everyone know about this website I found about DSM injectors. http://www.dsm-performance.com/telcatalog.html Check it out. From what I am hearing, I am thinking of tossing the RC's and going with the DSM 750's for my Hondata reprogram.
dbman96, you said you are currently using DSM injectors, will the ones on the site I listed work for me? I plan on upgrading my fuel rail anyway, but I shouldn't have to modify it in anyway right? Thanks,
gsr*lude
gsr*lude
Re: physical mod to fit DSM injectors... (gsr*lude)
Very interesting Holley injectors... 5 hole squirters... now if I just didn't have to run a resistor pak... Just want to run the Hondata and some real big freakin' injectors...
Re: physical mod to fit DSM injectors... (Zeus)
Hmm...thats interesting I just got some 450cc off a 95 eclipse and they did not fit my obd1 injector plugs.
Re: physical mod to fit DSM injectors... (98hx99b18c)
98hx99b18c: Just remove the plastic pin in the injector with a blade and they will fit your harness.
092eg6
12-23-2009 01:38 PM
