to build a B18B or B18C? that is the question
Old Aug 10, 2001 | 11:17 PM
DIRep972's Avatar
Smarter than you
Default to build a B18B or B18C? that is the question
well i dont even have my turbo kit on yet but i am think way in the future.. what would everyone do? lets say u already have a turbo LS integra with standalone and u r ready to build the motor and turn up the boost.. would u A) use your B18B you already have and sleeve it, rods, pistons, etc or B) buy a B18C and do the same, sleeves, rods, pistons...
the B18C will obviously make more power but it will also cost u more to build it and buy it..
if u were to swap a GSR in a LS/SE what all would u need to go with it just oil pump? water pump? u wouldnt need an ECU if u r standalone right?
Old Aug 10, 2001 | 11:28 PM
Ray's Avatar
Ray
New User
Default Re: to build a B18B or B18C? that is the question (DIRep972)
well the for the price of just getting the stock gsr motor you can fully build your ls
Old Aug 10, 2001 | 11:53 PM
SIK IN DA HED's Avatar
New User
Default Re: to build a B18B or B18C? that is the question (Ray)
i agree with ray. think about the pros and cons. ls motors have lower compression, which is better for turbo. downside is that when you build it, you cant tach it as high as a gsr motor, but you have alot more torque. then people would say to get a gsr motor cause you can lower the compression and prep it for turbo. and since a gsr has vtec, its an additional plus. or you can get an ls motor and convert it to lsvtec. then people will say its not as reliable. all i got to say is... go with the best combo suited for your needs. one motor is not going to get you more power than the other. its how you build it!
personally... id get the ls motor and make it lsvtec. build it right... slap on a turbo kit... and youll blow alot of ls and gsr motors away.
[Modified by dlplayboy, 12:55 AM 8/11/2001]
Old Aug 11, 2001 | 12:01 AM
DIRep972's Avatar
Smarter than you
Default Re: to build a B18B or B18C? that is the question (dlplayboy)
personally i think if a LS motor reved to 8000 like the GSR and they both had cam gears tuned the GSR would make slightly more power only becuase the head flows better.. is there anyway to make a B18B rev that high? safely and reliably of course..
Old Aug 11, 2001 | 12:21 AM
Ray's Avatar
Ray
New User
due to the longer stroke of a LS I would keep the Rpms lower due to the high piston speeds. Of course you CAN rev an LS to 8,000+ rpm but unless you have vtec it would just wear the piston rings more.
Old Nov 5, 2003 | 01:25 PM
30psi Teg's Avatar
How about just buying another b18a/b block and building that one then you can just slap your head on that or you could even get another ls head. **** high mileage ls motors go cheap
Old Nov 5, 2003 | 01:40 PM
Mase's Avatar
Default Re: (30psi Teg)
haha, wow old, this is when chris was a retard. uhh wait, i mean, this is when chris was really really retarded.
Old Nov 5, 2003 | 01:49 PM
quikB18B's Avatar
Default Re: (Mase)
Chris made this thread on my 20th b-day
Talk about back from the dead
Old Nov 5, 2003 | 01:55 PM
espanol's Avatar
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">haha, wow old, this is when chris was a retard. uhh wait, i mean, this is when chris was really really retarded. </TD></TR></TABLE>
lol...
Old Nov 5, 2003 | 02:14 PM
Johnyquest's Avatar
Default Re: (espanol)
Of course you can rev an ls shortblock to 9000 if the internals are built. **** r/s ratio if your rods/sleeves etc are all aftermarket strong goodies.. I'd say go for it.
Old Nov 5, 2003 | 03:53 PM
DIRep972's Avatar
Smarter than you
Default Re: (Johnyquest)
DUDE THIS IS BEFORE I WAS EVEN TURBO!!!! omg GSR ALL THE WAY!!!!! DUHHHHHHHH hahahah
Old Nov 5, 2003 | 04:00 PM
quikB18B's Avatar
Default Re: (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">DUDE THIS IS BEFORE I WAS EVEN TURBO!!!! omg GSR ALL THE WAY!!!!! DUHHHHHHHH hahahah</TD></TR></TABLE>
Back when you were stuck in the 16's
Old Nov 5, 2003 | 04:27 PM
Ben Huynh's Avatar
Here's a for Chris.
Old Nov 5, 2003 | 06:03 PM
LSiTurbo's Avatar
Default Re: (ben@importparts.com)
I rev my built LS Turbo to 8600 and it cover some ground all the way there! High reving LS motors are definatley possible, they have to be well balanced like any motor and have some cams to make it work up top also. Im running REV valvetrain with .5mm OS valves and Crower 402Ts and love it. I am a firm beleiver in LS motors
93 Eg Couper
Dec 13, 2008 03:17 PM
Spec R_GSR
Aug 21, 2006 11:02 AM
stock_cx
Nov 10, 2004 08:46 AM
xTeg
Jul 9, 2002 10:44 PM
