Can i lower compression by just using a thicker headgasket?
Old Aug 15, 2001 | 05:40 AM
WuShu's Avatar
New User
Default Can i lower compression by just using a thicker headgasket?
its a 91 crx and it will mostly be used for street and occasional strip, can i lower compression by just using a thicker head gasket? ive heard its cheaper way to do a street setup.
Old Aug 15, 2001 | 05:42 AM
redline's Avatar
Default Re: Can i lower compression by just using a thicker headgasket? (HondaCRX)
yes you can.
Old Aug 15, 2001 | 05:52 AM
WuShu's Avatar
New User
Default Re: Can i lower compression by just using a thicker headgasket? (redline)
Is it reliable?
Old Aug 15, 2001 | 07:18 AM
redline's Avatar
Is it reliable?
It seems that some people like them and other do not. But if it is a high quality gasket i do not see an issue.
Old Aug 15, 2001 | 07:38 AM
WuShu's Avatar
New User
can you suggest any?
Old Aug 15, 2001 | 04:47 PM
Gmedalion's Avatar
f-max
Old Aug 15, 2001 | 09:16 PM
dragonsmp's Avatar
New User
Default Re: Can i lower compression by just using a thicker headgasket? (dc2jdmhonda)
greddy
Old Aug 16, 2001 | 11:35 AM
jinxproof99's Avatar
New User
INLINE PRO......and they're in virginia. 703-644-1788
[Modified by jinxproof99, 3:35 PM 8/16/2001]
[Modified by jinxproof99, 4:10 PM 8/16/2001]
Old Aug 16, 2001 | 01:03 PM
liam821's Avatar
25 Year Member
Default Re: Can i lower compression by just using a thicker headgasket? (dragonsmp)
greddy
As far as i know, greddy only makes thick head gaskets for the d16z6 (sohc vtec) motor..not the CRX. But...the z6 gasket should work on all 88+ d-series honda motors.
I am currently using a 88 CRX paper gasket in my d16z6 because it was $18 vs. the z6 metal gasket which is $58. *grin*
liam
Old Aug 17, 2001 | 08:12 AM
Type-ARR's Avatar
Default Re: Can i lower compression by just using a thicker headgasket? (liam821)
I Use a Blitz 7 layer head gasket on my Type-R and run 7psi no problem. Inlinepro has head gaskets but they did not lower my compression enough but they might work for you. Just ask Inlinrpro they are the ****!
Old Aug 17, 2001 | 02:29 PM
apexii's Avatar
Default Re: Can i lower compression by just using a thicker headgasket? (Gmedalion)
fmax does not make one. They supply the rIdeal one with their kits as an option. I think it's made by mr. gasket. I have it and it's held up fine for 18months and 2 motors. It gives you ~8.8:1 c/r.
Some people feel it's an incorrect way to lower compression, and I tend to agree to a certian degree. It's like milling the head to get a higher c/r. It may not be the best option, but it gets the job done.
rspectuning85
Dec 11, 2004 01:45 PM
.::Lee::.
Feb 17, 2004 08:50 PM
USDM 4G VTEC
Sep 16, 2003 09:17 AM
extrmeboost
Mar 30, 2003 10:19 PM
Evs-One
Mar 3, 2003 01:09 AM
